Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 06-17-2004, 09:05 AM   #1
Dave Laurer
93 Lumina No start
I have read several posts here about no starts. But mine is a bit different. I am experienceing random no starts and random stalling. Usually after a hot soak. This morning no cold start. This is a first. Every time usually it will fire for less than one second and stall immediately. Eventually it will fire and be OK. I gave up this morning, but it still fires and quits.
It DOES HAVE spark and fuel which is different than most other complaints I read here.
I am thinking low fuel pressure (will measure tonight) not enough to open the poppets or some sensor throwing of timing (will throw a light on it tonight)
Dave Laurer is offline   Reply With Quote
Old 06-18-2004, 01:33 PM   #2
sysopt
Re: 93 Lumina No start
If the EGR valve on your car is vacuum operated, check to see if its getting stuck open.
sysopt is offline   Reply With Quote
Old 07-06-2004, 11:43 PM   #3
troubleshooter
I had a similar problem recently which led me to change the throttle position sensor, the idle air control valve and the vacuum canister purge valve. This took care of my problems.
troubleshooter is offline   Reply With Quote
