Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 06-17-2004, 12:35 AM
daveycarpet daveycarpet is offline
How can one tell if ignition switch needs replacing?
Could some one let me know when the ignition switch needs replacing?
What are the tell tale signs?
Any help is appreciated.
Thanks
Davey Carpet
Old 06-17-2004, 09:56 AM
umina umina is offline
Its been my experience that if the key won't turn the ignition (assuming you're using the correct key) or if the key gets stuck in the ignition or won't turn to ACC, you will need to replace the ignition switch.
