Old 06-16-2004, 11:53 PM
sdzc420 sdzc420 is offline
Question clutch problems
With the engine off, I can select different gears, but when I start the motor in nuetral I can't get any gears. If I start the car in 1st gear, the car will run, but I can't get it out of gear or change gears til the motor is off again. Basically I did a motor&tranny swap myself and need to know if Im gonna have to replace the new clutch again or adjust the clutch. If its an adjustin' it needs, I need to know what kind. Any help will be greatly appreciated.
Old 06-17-2004, 11:49 AM
YellowITR479 YellowITR479 is offline
Re: clutch problems
Does not sound like a clutch problem but I dont know too much about tranny's.....is your linkage installed properly?
1996 GSR w/ 1995 OBD-1 B18C1, Hondata S200 w/ P61 ECU, LS Tranny w/ Quaife LSD,ClutchMstr Stg 5,T/4 AR .60 w/ HKS Wastegate,RC 660 cc Injectors,Had Throttlebody,Skunk2 Intake Manifold,Eagle Sleeves,JE Pistons, Carrillo Rods,Stock Head & Internals,Thermal 3" Exhaust w/ no Cat,AEM Fuel Rail-Riser-UEGO-Cam Gears-Pullies-Fuel Filter,255 Fuel Pump,MSD 6A,GReddy Front Mount, 2-12's, 3 Amps,MB QuartComponents,Type-R Lip & 00 Head & Tailights,
2000 Integra Type R: Totaled
Old 06-17-2004, 03:16 PM
clutch problems
to my knowledge it is. why would I be able to shift gears w/ the motor off but not running?
Old 06-17-2004, 07:11 PM
knorwj's Avatar
knorwj knorwj is offline
Send a message via AIM to knorwj
your clutch isn't releasing from the flywheel when you push in the clutch. you may possibly have a bad throw out bearing. soon the car will start to not "stop" when you push in the clutch and will stall when you apply your brakes just as if you hadn't depressed the clutch.
you say you have a new clutch? what about throw out bearing? anyway try adjusting it.
by the way what type of car is it? is it cable or hydro tranny?
Old:
1993 Acura integra gs-r
New:
1998 chevy BlaZeR2~ AKA "Jeep recovery device"
Newer:
2007 Honda CB900F "919"
Old 06-20-2004, 01:19 AM
Re: clutch problems
its a 88 crx w/ a dohc zc motor, L3 tranny, cable clutch.
