Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 06-16-2004, 09:45 PM
quake quake is offline
95 Caprice Classic Engine Dies 2
It use to run awhile then shut off. Now it cranks once in awhile for a few seconds. Has new fuel pump and pressure,dist,module and coil. It has no fire from the coil. Someone told me you have to have the ecm or pcm programmed at the dealer. I was wondering if this is true. I've tried unhooking the battery and unplugging the o-sensors. Any suggestions.
Old 06-17-2004, 05:36 AM
CD Smalley CD Smalley is offline
Re: 95 Caprice Classic Engine Dies 2
Some GM engines have an oil pressure switch. They require X psi of oil pressure to allow the ignition to fire. Does the LT1 or L99, not sure which you have, have such an animal???
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 06-18-2004, 05:18 PM
Nope didn't work. Runs for a minute and quites.I think Lack of oil pressure stops the fuel pump.
