Old 06-16-2004, 08:15 PM
gjimene2 gjimene2 is offline
92' Taurus 3.8 A/C problems
I replaced the compressor in my 92' Taurus which has a 3.8 V6 in it.
I also replaced the line that is from the dry line that leads to the condenser.
I'm know that my lines are contaminated because the freon when tested came out black. Also to make matters worse while reving up the engine I noticed that the compressor made a whirling noise and threw sparks at me
I believe that the system had R-12 in it which was completely drained and vacuumed prior to getting some 134a in the lines. I also think that the compressor didn't have synthetic oil in it and thus contaminated the lines.
My question is, if I take the car to a shop to get the lines "resotored" (emptying out the lines and flushing them completely) , chop the line to replace the filter, and put some new 134a and oil. Or should I just replace the rest of the ac line dryer and all and add 134a. Or just restore, change filter and use Freeze-12 instead. I can get some Freeze-12 around here localy.
So what do you guys think?
Old 06-17-2004, 11:31 AM
Dan_in_WA Dan_in_WA is offline
Send a message via AIM to Dan_in_WA Send a message via Yahoo to Dan_in_WA
Were the sparks from the compressor from the clutch? Or from the solenoid coil behind it?
Your problems sound serious enough that I'd take it to a good shop, and have them do the full monte on it; or else this thing is going to nickel and dime you to death trying to keep it running.
