Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 06-16-2004, 08:00 PM
96Civic_Coupe 96Civic_Coupe is offline
Banned
How Often.....
i just bought my first car about a month ago. i know when im suppose to change my oil but how often am i suppose to change my coolant, transmission oil, spark plugs,wires,air filters,power steering fluid, and belts.
Old 06-16-2004, 09:46 PM
SenseiAccord SenseiAccord is offline
Re: How Often.....
oil & Power steering... about every 3000 or 3 months. Coolant, Tranny, plugs, wires, air filter.... about every 30,000 or 2 years. belts... about every 80,000 or 5 years... i think
Old 06-18-2004, 09:44 AM
BullShifter's Avatar
Re: Re: How Often.....
Power steering fluid every 3000 miles? That's a first.
What's the year & model, the maint. schedule is different.
Air Filter - every 15-30K, buy a K&N and never change it.
Manual trans or auto trans - every 30K or 2yrs
Coolant - 30K then every 45K after
TIMING BELT, belts, & water pump every 90K or 105K depending on model/year.
Spark plugs, plug wires, cap/rotor repalce as needed
Fuel filter - every 30K depending on year/model
My best suggestion stop by the dealer & pick up a maint. schedule or purchase a Honda repair manual from www.helminc.com not only will it tell you the schedule it will walk you through all the steps to perform these services.
Brakes should be cleaned, inspected, lubed, *adjusted every 15K.
Tires rotated every 7500 miles
Old 06-18-2004, 12:58 PM
Tranzlogic Tranzlogic is offline
Send a message via AIM to Tranzlogic
Re: How Often.....
you dont change your PS fluid at 3k miles...who told you that jiffy lube ? seriously...look if its a use car..change your oil,tranny,coolant,top off your PS fluid ( remember to use HONDA fluid ) and your clutch resevoir with brake fluid along with your master cylinder....this will ensure all fluid are new and fresh in the vehicle....then every 3k on your oil and filter, about 15k on your tranny ( if its an auto ) and i like to change my coolant once a year..just inspect your belts and look for fray's and so forth..check your milage aginst yout t-belt also if ti hasnt been done..there should be a sticker along the timing cover if it has been done ..well by a shop that is...take everything else as needed
Old 06-18-2004, 07:50 PM
Re: How Often.....
http://www.binghamtonlife.com/manual...ges/91-4-4.jpg
http://www.binghamtonlife.com/manual...ges/91-4-5.jpg
http://www.binghamtonlife.com/manual...ges/91-4-6.jpg
Old 06-18-2004, 10:46 PM
Re: How Often.....
i meant to at least check it with every oil change just like how u should check all the other fluids to see their condition.
Old 06-19-2004, 01:58 AM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
I was told by the dealership recently (at least reguarding 6th gen Civics, '96-'00) that the fuel filter not need changing but every 80k or so. I went in to price it out, and when they asked my mileage (44k on my '00 Civic coupe) they told me not to worry about it till at least 70k - 80k miles. Sprak plugs they recommend changing at about every 30k. I just changed mine for the first time since the car was bought, and even at 44k miles, hard driving and several auto-X'es under my belt, and they looked as good as 44k old plugs could look. NO oil residue, carbon build up from gas, or any other irreularities on them to speak of. They just looked like they got a good life of use out of them.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
