Old 06-16-2004, 04:20 PM
smokeymicpot smokeymicpot is offline
Send a message via AIM to smokeymicpot
hello again motor swap and beef up
how hard would it be to beef up a d16a1 to about 200 hp wiht out turbo and nos? i can find cams but is there any thing else out there for them?
i can get the hole motor and trans everything i need to put it in my civic for 300
Old 06-16-2004, 04:58 PM
Beyond Imagination's Avatar
Beyond Imagination Beyond Imagination is offline
Re: hello again motor swap and beef up
it's not had as long as you have the money
88 Honda CRX Si - B16
90 Honda CRX Si - B20VTEC
Old 06-16-2004, 07:28 PM
viper_2_4's Avatar
viper_2_4 viper_2_4 is offline
Send a message via MSN to viper_2_4
I hope you are using a 3rd gen civic, because the d16a1 is not a direct bolt into the 4th gen (d16a6 is, and the JDM ZC)......
Old 06-17-2004, 01:01 AM
its in a 87 teg it looks like the same bolt up there in the same place sides and all but who makes parts for it?
Old 06-17-2004, 12:29 PM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
The 86-89 teg motors do NOT bolt into 88-91 Civics.
86-89 Integra - based on 3rd gen Civic 84-87
90-93 Integra - based on 4th gen Civic 88-91
However, 90-93 Integras have b-series motors, which still require mounts to fit in 4th gen Civics, but a lot of other parts will bolt in if they fill the niche - i.e. rear disc brakes from a 90-93 Integra bolt directly onto 88-91 Civics, but the front suspensions are not identical.
The d16a1 motor only makes 118HP, so it is only 10 more than an 88-91 Civic Si d16a6 motor. Not worth the hassle in my opinion, AND it does NOT bolt in.
Even a 92-95 Civic vtec (d16z6) makes 125hp or a 96-00 (d16y8) makes 127hp and they bolt in (these require some wiring mods however to work with a 4g)
Another option is the JDM ZC (mentioned above) - there are a zillion differet versions, but the black valve cover DOHC version makes 130hp, bolts in directly, and doesn't require too much wiring..These are older motors tho (out of Japenese Civics & Teggy's) and are getting hard to find in good shape.
Try these links...they will help tremendously...
http://hybrid2.honda-perf.org/tech/4gtech.html - old site but good info with more text
http://tech.hybridgarage.com/tech/4gtech/index.html - new site in table format
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Old 06-17-2004, 03:19 PM
travagliante's Avatar
travagliante travagliante is offline
Yep look for a SOHC ZC engine. They are jdm, very cheap, seen them for like 400 bucks, 130hp. Vtec, 9000 redline.
Direct Bolt in! Just have to run 2 wires for vtec.
Old 06-18-2004, 12:07 AM
Hilikus Funkin's Avatar
Hilikus Funkin Hilikus Funkin is offline
Send a message via AIM to Hilikus Funkin
is the SOHC ZC the D15 vtec engine thats on ebay every once in a while?
1991 Honda Civic DX Sedan
