View Poll Results: what sh
rims 0 0%
cobra ground kit 0 0%
blackout headlights 0 0%
underdrive pulleys 2 100.00%
Voters: 2. You may not vote on this poll
Old 06-16-2004, 03:08 PM
89TX5.0 89TX5.0 is offline
Talking next mod?
I am about to get a job that ot very good payin and I want to see what I should get next? I have a crane cam, rockers,performer intake,performer heads, bbk headers, bbk x-pipe, magna flows, 75mm maf sensor, 70mm throttle body,4-10 gears, shift kit, 25 lb injectors.
Should I try to get..
rims
cobra ground kit
blackout front light
underdrive pulleys
Old 06-16-2004, 03:09 PM
redhorseV6 redhorseV6 is offline
Send a message via AIM to redhorseV6
Re: next mod?
underdrive pullies. don't black out your lights, it looks silly. also, underdrive pullies are cheap so can probably afford to get rims at the same time. happy shopping.
Old 06-16-2004, 03:12 PM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: next mod?
Stall converter, before anything else!
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 06-16-2004, 03:38 PM
what is a stall converter?
Old 06-16-2004, 05:55 PM
Cobra01TT's Avatar
Cobra01TT Cobra01TT is offline
Re: next mod?
Supercharger, Stroker Kit, or Locker.
2001 Ford Mustang Cobra - Straight piped and loud as hell
2002 Yamaha R6 - Micron exhaust
1987 Chevy Corvette Convertable A.K.A. - The Pimpmobile
Old 06-16-2004, 09:27 PM
351wStang's Avatar
351wStang 351wStang is offline
Re: next mod?
A stall converter or torque converter are basically the same thing, serve the same purpose. Only a stall converter will let your engine rev to a givin rpm before putting much if any power to your wheels. You will get much better performance out of your cam with a new and correct converter. Also I would suggest a spool, less than $100 and a big improvement.
Old 06-17-2004, 01:26 AM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
stall converter/ torque converter. Same thing.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
