Old 06-16-2004, 02:34 PM
matt919's Avatar
matt919 matt919 is offline
Send a message via AIM to matt919
int. lights
does anyone know if theres a way, so when i open my doors, just the lights on the floor come on? Instead of the 4 on the roof also? thanks..
Old 06-16-2004, 05:58 PM
michelq michelq is offline
Re: int. lights
yes pull the bulbs that the only way or rewire the sys
Old 06-17-2004, 04:35 AM
matt919's Avatar
Re: int. lights
well.. i still would want to use the Roof lighst when i needed, but i thought maybe since the lights are hooked up so when the door is open, they come on.. maybe someone knew where or how i could disconnect the roof ones only from that feature.
thanks though.
Old 06-17-2004, 01:24 PM
grfnkl's Avatar
grfnkl grfnkl is offline
Send a message via AIM to grfnkl
well you have 2 other options besides pulling the bulbs, You can either wire in a switch to the light so it could be turned on and off when needed, or wire in a new light fixture, from a newer G/a or something that has the on/off switch as well as the regular door mode, But that one may require more rewiring.
Old 06-18-2004, 01:08 PM
e2helper e2helper is offline
Re: int. lights
It should only require removing 1 wire from an inline wiring connection between the body and headliner harness to get the functionality you are looking for. It will likely be a white wire. You would also lose the potential for turning on your overhead lights using the "dimmer switch" on instrument panel.
You have a 1993, correct?
Old 06-18-2004, 03:12 PM
matt919's Avatar
Re: int. lights
correct, 1993.
i'll have to screw around with it
