boost leak
Ok, so I am beginning to think I have a boost leak somewhere. It sounds like my turbos are more audibly spooling. I don't feel the low-end torque as much now, and I really think I have a boost leak. So being that I am entirely broke after paying car payments, rent, and car insurance, I don't have money for a pressure tester. So I'm wondering if the soapy water trick actually works? Do I just put soapy water all over everything and give it some gas and look for bubbles or what? Any do's and don'ts would help. Thanks, Geoff
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
Re: boost leak
Good Luck. Use a Friend to hit the gas if you have actual boost leaks via turbo, intake, intercooler lines, otherwise you can find vacuum leaks yourself fairly easily. |
Re: boost leak
Hey I appreciate the advice, unfortunantly it doesn't look like the weather will hold off long enough for me to do it. I had to solder my radar detector wiring back together as it got sliced. I sent you a PM with a few more ?s
Re: boost leak
I read somewhere that with a vacuum leak, an engine will idle a bit higher, is this true, and where do your vr4s typically idle?
Re: boost leak
my gto ticks over around 900rpms with no air con on. does your turbos make a louder whistling noise than usual? if so its rebuild time..........
mine made a louder spool noise for a few weeks before the front one shat itself but if you catch it in time you can put a rebuild kit in.......... or buy your 15g's!!!!!!!!!!!!!!
1993 Mitsubishi GTO Twin Turbo (RHD) NOW SOLD!!! 9b turbos with manual boost valve mod set @14psi turbo xs type h-rfl blow off valve blitz dome filter sachs clutch completely de-catted fuel pump voltage rewire mod ebc redstuff front brake pads greddy fully automatic turbo timer now drives a sensible family sedan. A 340hp 1997 mitsubishi evolution IV
Re: boost leak
They aren't whistling, it is just when I stomp on the gas, I don't get pushed into the back of my seat as hard as I used to, the turbos sound the same as always, I just think it is a bit louder and more noticeable. It just feels like the power isn't completely there 1st through 4th gear. If I cruise it still feels like all is normal, but when I get on the boost at WOT in the low gears, I don't feel like it pulls as hard. I just wish I had some way to confirm my suspicions. I don't have a pressure tester, don't have an aftermarket boost gauge, and I don't have the time to take it to the track.
I wont pay for a rebuild kit...if they blow...I'll be pissed for a min or 2 and then glad that I will be forced to buy the 15Gs. But right now it is just annoying. I do idle at around 900, so that is good. Dammit I hate troubleshooting.
