Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 06-16-2004, 12:56 PM
Ideasworking Ideasworking is offline
Lots and lots of PINGING!!!
Hello,
I have had my car (1995 w4.6L) in the garage a few times now, once at the Ford dealer, then I tried a couple other garages. My complaint is always the same... under heavy acceleration the car pings (pre-detonation) like crazy. Has anyone else experienced this problem and more importantly, have you corrected the problem?
Thanks,
Lou
Old 06-16-2004, 11:55 PM
thunderbird muscle's Avatar
thunderbird muscle thunderbird muscle is offline
Re: Lots and lots of PINGING!!!
What fuel grade do you use?
A founding member of HNF car club!
Do you know what it feels like to do an amazing burnout listening to that wonderful exhaust note, Oh you drive a honda sorry dude, but theres hope they still make nitrous oxide!
Racing a Honda is like being in the special olympics even if you win your still retarded!
Old 06-17-2004, 05:38 AM
I use regular unleaded... does it really make that big of a difference? What's the compression ratio?
Old 06-17-2004, 02:36 PM
solaris=amazing's Avatar
solaris=amazing solaris=amazing is offline
I think i have the same exact problem. Only when i floor it at a stop, also at speeds like 55mph, then it will ping(sounds more like a chain clacking ie. timing chain) when i floor it at 55mph and over. Only pings when i get on the gas really hard. Normal driving is not the problem. I first thought it was a loose idler wheel-which aint the case, i believe its got something to do with the timing chain inside the block. Not spark plugs either-cause plugs would be pinging at normal speeds.
Old 06-19-2004, 08:19 PM
flewthecoupe's Avatar
flewthecoupe flewthecoupe is offline
What codes, if any, were present? If they weren't pulled, go do it. Some of the major parts houses do it for free.
It's not how fast you can go, it's how fast you can get there.
Proper grammar, it's not just for English teachers.
I don't pick on any one person, I treat everyone this way.
My only pleasure is tormenting those people who work for me.
There are no stupid questions, just a lot of inquisitive idiots.
Old 07-18-2004, 04:11 PM
Bassist Bassist is offline
Hey, i have the same problem with my 96 tbird 4.6. My codes were p0171 and po174 system too lean bank 1 and 2. I've been looking at some of the other forums and it seems this problem is a big pain to troubleshoot. Ive heard some success stories from other guys eliminating this problem by cleaning the throttlebody, fixing some vaccum leaks and making sure the egr is working properly. I am in the process of cleaning all the gunk from my throttlebody and egr. Also, there is a little black canister mounted to the front left of the engine that regulates vaccum pressure to the egr. This and/or the egr could cause this problem by letting exhaust gasses preignite the fuel. I'll keep you all posted on my progress.
Old 07-19-2004, 12:38 AM
Mike75 Mike75 is offline
Re: Re: Lots and lots of PINGING!!!
Thank you - please do.
Old 07-20-2004, 03:58 PM
It could be your knock sensor....
Old 07-23-2004, 12:26 AM
jlewis jlewis is offline
Send a message via AIM to jlewis
Okay, here's the fox body guy butting in. the 4.6 timing is nonadjustable right? So it must be that it's running lean like the codes say? It could be the knock sensor but it could also be the oxygen sensor, but normally if the 02 sensor goes bad it normally reads rich but makes the engine run lean because it can't detect the oxygen correctly. Well, I've done no good here but maybe I brought up some ideas, later.
Old 07-25-2004, 03:01 PM
Car Pal Car Pal is offline
ping on accel? carbon build-up on the piston heads
172,174 lean and banks 1 and 2.cacuum leaks at the intake. ck the vacuum lines around the intake.
also the maf controls the fuel air mixture;some times you can fix it by cleaning the hotwire.
if you can see the baro pressure pid you can tell if the car has learned some bad habits.disconnect the negative cable for 10. min.
Old 07-29-2004, 08:14 PM
sleepyjoe927 sleepyjoe927 is offline
I would bet $$ that it is the MAF sensor. The original ones had problems.
I had this problem too. Even with 93 octane, it pinged loudly under all throttle loads.
I replaced the MAF sensor and the pinging was immediately gone, the acceleration was noticeably improved and the gas mileage went up. It was well worth the cost to replace it.
You can try cleaning the MAF with a shot of carb cleaner, but you will probably need to just replace it.
- joe
Old 09-07-2004, 08:58 PM
mpyrol mpyrol is offline
Causes of my pinging problems have been as follows,
MAF (replaced twice), OR O2 sensors (4 of them), OR carbon buildup between the throttle body and intake where the egr goes into the intake, OR water in the air filter housing (it's the upward turn where the air goes into the filter assembly) OR head gasket leaking between cylinders. TPS may be culprit also. All can give the computer rich data. I have had these problems until I completed all this service except for head gasket (another t-bird). I could have bought a new car by now........... By far the most troublesome and expensive car I have every owned.
