Old 06-16-2004, 10:24 AM
TheAznPersuazun TheAznPersuazun is offline
Question Higher Compression
what are the procedures to get higher compression in my D16Y8....can i just put on a thinner head gasket or what?!?!?
Old 06-16-2004, 10:26 AM
rubix777's Avatar
rubix777 rubix777 is offline
Send a message via AIM to rubix777
get higher compression pistons
Old 06-16-2004, 11:55 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
higher comp pistons, thinner headgasket, shaving the head and block, valves
Team Lonely Drivers
Old 06-17-2004, 10:10 AM
Re: Higher Compression
say i didn't wanna spend the $ on internals cuz the turbo i'm getting comes with everything...would i still be able to put on a thinner head gasket or would i HAFTA get the pistons and cam?!?
Old 06-17-2004, 11:20 AM
Tranzlogic Tranzlogic is offline
Send a message via AIM to Tranzlogic
the turbo your getting is comming with internals ??? and you dont wanna raise your compression if your going boost anyways..what turbo kit is this..cause that will depend on the boost variables and how much bosot you plan on running and so forth..shoot more info
Old 06-17-2004, 01:07 PM
jcrx jcrx is offline
Send a message via AIM to jcrx
valves huh?
Old 06-17-2004, 01:54 PM
well i kno i would only be able to run 5-7max boost so i've only put on it so far was plugs, wires, cold air, pulleys, and ground wires....i'm trying to do things i wouldnt hafta change or get rid of. So i was thinking of getting a Greddy turbo kit...what do u think?
Old 06-17-2004, 01:59 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
Re: Re: Higher Compression
Oh really? What kit is this that comes with internals?
Do you want to blow your shit up? Raising compression then forcing boost on top of that is retarded 'cuz'.
Got news for ya, the turbo replaces your cold air intake.
Old 06-18-2004, 02:13 AM
yes valves that can increase your compression alittle, not much but just alittle.
you dont need aftermarket wires, oem honda wires are good. some guys running 500whp run honda oem wires.
you wont need any internals with 5-7 psi, i would just recommend a good engine management system
Team Lonely Drivers
Old 06-18-2004, 10:17 AM
im aware that the kit would replace my cold air, but that's about the only thing that i would hafta worry about getting rid of...which wouldn't be hard.
Old 06-18-2004, 12:52 PM
well what do you want !? high compression or a turbo ? you cant have both on the engine itself..rather high compression all motor or low compression turbo for the turbo will raise....theres allt his talk about high comp pistons and then talk on turbo kits...which is it ?
Old 06-18-2004, 08:34 PM
Valves don't increase your compression stunna. The size of the reliefs can possibly affect it in minute ways that can only be calculated in a .000 addition to the rest of the volume calculation. Valves can affect compression test as in if they aren't seated right, air can slip by, but not what he is talking about.
Old 06-18-2004, 10:33 PM
soccmid soccmid is offline
Send a message via AIM to soccmid
im plannin on turboin my lude si with comp 9.6:1 stock, but most aftermarket pistons for the h23 come only in 9:1 and 10:1. id like to change over to the 10:1 pistons simply because i am doin all my internals( sleeves, pistons, rods, valves, retainers, valve springs) as one step and then later i will complete the car with the turbo setup. i would rather not lose .6 compression for 4 to 6 months while ordering and finding necessary turbo parts. Could i safely run 10:1 on say 12 lbs of boost with all the internal work already completed?
thanks
"You can't do anything worth doing in life without taking a chance" - me
funny shit
Old 06-18-2004, 10:58 PM
SenseiAccord SenseiAccord is offline
to tell u the truth... running 10:1 with turbo is not a good idea. If u want more boost... bare with the low comp for tat 4-6 month period and then when ur turbo is in... u have the rest of the cars life to have fun with. i'd say with 10:1 comp... u wont be able to run more than 8 lbs unless u use racing gas.
Old 06-19-2004, 12:33 AM
oh so i am wrong huh, ever heard of skunk2 high compression flat valves ? but thanks for clearing it up, im glad to find out that im wrong.
ok so valves have alittle dip in them, but with these valves, there is no dip and its all flat so therefore it raises your compression.
please dont talk if you dont know what your talking about.
you can run 10 cr you just need a really good tune and keep your eye or ear open for knock. but runnin higher compression will make your max boost lower. you can run more then 8psi, i seen type r's running 8 psi on there 11.5 cr.
Team Lonely Drivers
