I have a 98 w/65K on it. Reading the owners man, it says that I may never need to change the trans fluid in it. It still shows that it is at 100% but it worries me to leave it go if it will cause problems later. So far all is smooth with it. I know a person that has a 97 w 105K and his is also at 100%. Is this a good idea to leave the fluid in there that long? Or, if its working good, better to leave it alone. ?? Thanks all.
no matter what, the console will always show 100% transmission fluid life. To answer your question, you should definately get it changed. Not changing it can greately reduce the life of your transmission. I would say every 30,000 miles is a good interval. You want the shop to drop the pan and replace the two screens and put on a new gasket. If you are a DIYer, its a few hour job. I did mine a few weeks ago and it didnt take long at all. About $10 for fluid and $25 for the gasket/screen kit. Much cheaper than the $150 - $200 a shop will likely charge.
Do you know if there are any band adjustments while I'm in there? Thats a big looking pan! I did my Dodge truck, and screwed up the adjustment and had to drop it again. No fun. Thanx!
Re: Tranny Fluid Change
well unless your shifting your tranny hard like shifting gears and all that and going really fast all the time and you check your fluid and its not a good red color like it should be then you should replace it but if your driving normal and the tranny fluid looks good keep it.
[On his running for California Governor] It's the most important decision I've had to make since 1978 when I decided to get a bikini wax. -- Arnold Schwarzenegger Politics is not a bad profession. If you succeed there are many rewards, if you disgrace yourself you can always write a book. -- Ronald Reagan "I wrote a book" --Bill Clinton |
Interesting counterpoint here. I was stuck in stop and go traffic some weeks ago and the next day the DIC showed Change Oil and Tran Fluid Now! Went to the closest Jiffy Lube and had the do an oil change AND tranny change. A couple of days ago...same thing...WITH LESS THAN 800 MILES ON THE LAST REPLACEMENT!!! What gives?
I do think there are sensors somewhere that tell the DIC that the fluid is bad. They just don't seem to do anything for regular usage. I too never had the life go off 100% before (or since) I had to limp home a couple hundred miles in 2nd gear. I apparently burned the crap out of the fluid according to the tranny shop. My DIC went from 100% to either 40 or 60 left- I forget now as it doesn't really matter. Check your fluid to make sure it looks good, then I suppose have someone look at it to find whatever is telling it that the fluid is bad.
I'm a little concerned as my tranny life went from 100% to "change now" literally overnight, along with the oil going from 40% to "change now" at the same time. I think maybe I'll get on that one this week.
Well, I think I should probably plan on doing it. The fluid is not as red as it should be. Is there anything speacial about doing it, or is it just messy like any other tranny? I'm too cheap to take it to the shop if I can do it on the ground myslelf.
I need some advice here..... I called Olds Dealer here and got the cost on the tranny fluid change. The filter is $36, the gasket is $36, or I can buy a kit for $91. The parts guy did not know what else was included in the kit. Is there possibly new o-rings or something else that I would need that may be in that kit? The whole pricing of this seems a bit high, but I checked with O'reilly and they also want 36 for the filter. Help! Do I try to find cheaper less quality? Or is the dealer parts the best way to go?
i am not sure about a 98, but i helped change out the filters in a 95.. there were 2 mesh filters in there, similar if not the same,they seemed quite clean and the only real dirt was inside the pan itself,we washed the pan out with solvent...
Stopped into my parts store for a filter and gasket kit for my '96. They had the filters, but no listing for a gasket.
The guy behind the counter suggested that perhaps the transmission had a reusable metal gasket and that a replacement was not required. Is this so - or do I need to keep looking for a gasket somewhere else? If so - where have others gotten one? Thanks - |
Thanks carver...
Based on newscarvers statement that the filter(s) were not that dirty, has anyone else seen the same? (Clean filters).? If they are coming out clean, is it possible that I can get one of those oil pump thingy's and just suck the fluid out from the filler hole? Or is there stuff in the way down to the pan? If in fact the filters from others are fairly clean, I am thinking if I can do what I suggest, it could benefit..? At least the fluid would be changed. Anyone else tried this? |
As easy as it is, just drop the pan and save the worry. To answer questions, I just changed my fluid 2 days ago. One of the easiest tranny fluid services I've done. VERY shallow pan helps a lot. Loosen all the bolts, drop the REAR of the pan to drain, that will get most of the fluid. When you take the pan off, there's little of anything left in there. There are 2 screens that pop into the tranny with rubber seals. The new seals will be supplied on the new screens. These screens always look clean, that doesn't mean they are. I pulled the right/rear one off (which looked fine) and fluid came gushing out after it. It was a 'little' clogged. I got my kit at O'Reilly for about $30 (discounted), 2 screens and a cork gasket. Throw the cork gasket away!! The car has a rubber impregnated steel gasket already, wipe it off with a clean rag (no solvents) and reuse it. The stock gasket has collars around all 16 bolt holes to prevent overtightening. Use the cork gasket and you'll dimple the pan and it'll leak like a madman. Mine took 6 qts ATF3, says 6.5 in the manual. Easy job, do it yourself but do it right.
-N8 |
For $30, I'll do it. I'll check with O'reilly again and bring em down. Another question though,,, I have the Autobahn deal and when I looked at AutoZone specs, it says I need 10 qts of DexIII,(possible needs that much?) guess I will try to keep track of what comes out, and guesstimate how much hits me and the floor..
On the gasket issue, should I put a small amout of sealer on it ? Thanks!! -phil |
