Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 06-16-2004, 09:57 AM
markheth markheth is offline
Change rings or not?
I am in the middle of doing a valve grind to my 89 240sx (230,000kms), and i was thinking of replacing the piston rings while I was at it...
Does this sound reasonable? or should I leave well enough alone, and just put the head back on...
If I change the rings, should I change anything else, or can I get away with reassembling the connecting rods/etc with all the same bushings, etc...
Old 06-17-2004, 08:07 PM
240fanatic 240fanatic is offline
Re: Change rings or not?
unless you plan on rebuilding the engine for more power then i would suggest to leave them alone
Old 06-17-2004, 08:52 PM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
Do you have the money? New shit is almost always better than old shit. You can just replace the rings, but replacing the pistons is a good idea. Did you ever do a compression test before you took the engine apart? By the way, 240fanatic, that is an awesome screen name. Where did you get it?
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
