Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 06-16-2004, 09:21 AM
Honda Dirt Racer Honda Dirt Racer is offline
where to find the engine series
I need some advice on where to go to find what engine is in my Prelude?I know where to look on the motor but it's gone. This is an older car it has a 1829cm2 CID 112 and the engine ID is C84D.This whole car was made in Japan. I just want to find outwhat engine series it is;the ownership says it's a 89 but they didn't put these motors in that year;they went to 2000cc. Hope some one has an idea where I can get this info... ( got this info off the stickers under the hood )
Old 06-16-2004, 10:24 AM
rubix777's Avatar
rubix777 rubix777 is offline
Send a message via AIM to rubix777
so you're saying the previous owner did an engine swap on your prelude or is this the original engine that came with it?
can you post a picture of the motor?
Old 06-16-2004, 11:53 AM
Re: where to find the engine series
this is the problem I real don't know if it's the origioal or not I beleive it is it has had some work done on it cause the block is painted Blue along with ither things lk starter one rear break so i'm guessing it's original. I can't get a pic. right now but it's got the dual carbs. does that help?
Old 06-16-2004, 12:02 PM
I can't post one right now . i know there's been work done on it cause the block, starter and a rear break that i looked at are painted blue. From what i know the guy that owned it wanted to keep it original. i aquired the car for some one else. it has dual carbs and the trani # is GM3639977 the engine # should be to the right of it on the block unless its somwe where else on Preludes thanks Dave
Old 06-16-2004, 04:32 PM
heres the pictures they are in my photo gallery
click here to see them
get back to me on this if they help thanks Dave E-me
Old 06-16-2004, 06:24 PM
rubix777's Avatar
if it's 1829cc, then it's gotta be
83-84 1829 cc ET1 Prelude. Twin carburetors, non CVCC.3/4 rocker shaft. Head casting # PC7X. N/A
83 1829 cc ES1 Prelude. Twin carburetors, CVCC, jet Valves Head
casting # PC6C, CB $255
84-85 1829 cc ES2 Accord. Single carburetors, CVCC, CB.
http://www.frautoparts.com/FREngine/honda.htm
Old 06-19-2004, 02:39 PM
Thanks for the info The serial # for the head is PC7C. If you know what car that was on.they made the dual carb SOHC 12 Valve 1829 cc till 1987. Then in 89 & 90 went to 1955 cc dual 12 v Thanks again I'd just like to know that engine series......
Old 06-19-2004, 03:03 PM
jcrx jcrx is offline
Send a message via AIM to jcrx
Engine code should be ES for that engine. The only other motors from the Japanese Preludes of that time (82-91) were the ES 1.8 and old B20As, carbed or fuel injected.
Old 06-24-2004, 08:59 AM
Re: Re: where to find the engine series
Thanks but the point is the engine # isn't on the motor.
Old 06-24-2004, 12:21 PM
I know for a fact that the B20A's have it, I saw one today. The ES should also, maybe it's under some schmegma.
