Old 06-16-2004, 06:31 AM
Newbie 88 Newbie 88 is offline
Front end noise???????
When the car is rolling there is a clunking coming from the front end of the car. I can actually feel it on the floor board sometimes. But, it stops when I apply the brakes and when I accellerate. What the F*ck? I haven't hit anything and this noise just started out of nowhere. I can't see anything broken or wrong. Any ideas?
Old 06-16-2004, 06:57 AM
Civic Jim's Avatar
Civic Jim Civic Jim is offline
Send a message via AIM to Civic Jim Send a message via MSN to Civic Jim
Re: Front end noise???????
does it do it around corners???? is it a cv joint, track rod end, ball joint, warped disks,
Jim - Your Resident EDM Biatch
B16A1 I/H/E
4TH GEN UK SITE
Honda Civic EE9 1.6-i VT
Old 06-16-2004, 07:54 AM
It does it whenever the car is rolling. Had the passenger side axle replaced, the brakes done and rotors turned about 3 months ago. It is not clicking the way the axle did.
Old 06-16-2004, 07:55 AM
Civic Jim's Avatar
wheel bearing??? , jack up the car and rotate the wheel and see if you can hear where the noise is coming from, then take off the wheel and see if anything is rubbing or hitting,
B16A1 I/H/E
4TH GEN UK SITE
Old 06-16-2004, 07:56 AM
1989_cash_eater's Avatar
1989_cash_eater 1989_cash_eater is offline
Re: Front end noise
If it's he same thing as in mine, it's really loud when you drive over dirt roads. A mechanic at honda told me it was a little piece near the tie-rod end that only costs about $10 (canadian).
"If you can read this...I'm Parked!..............Or broke down."
Old 06-17-2004, 02:15 AM
hazcc280 hazcc280 is offline
i had a fu*ked up noise...found out there was a bolt missing in the steering rack
Old 06-17-2004, 03:15 AM
RedRacerCivic's Avatar
RedRacerCivic RedRacerCivic is offline
Send a message via AIM to RedRacerCivic
Re: Re: Front end noise
What piece is that? is it rubber? Oh and Newbie, try checking out your motor mounts, see if they are in good shape, that "could" be a problem.
-1991 Civic Si (Sold)
-1990 Accord EX(Sold)
-2000 Civic Hatch
-1998 Lexus SC300
Click here to see my Shoe!
Old 06-19-2004, 12:41 AM
2ndb18's Avatar
2ndb18 2ndb18 is offline
Send a message via AIM to 2ndb18
im still bettin on the cv axles, they are the main place clicking comes from
88 civic dx
