Old 06-16-2004, 05:16 AM
SJ-91LX SJ-91LX is offline
My ZC bogs and sputters
I've had this ZC for almost 2 months now and it hasn't run right yet.
It's bogs so bad at low rpms that I have to rev it up past 4k to get it going and can't even drive in 5th gear.
I get no codes on the ecu.
I've tried PG7 and PM7 ecus with same results.
Put in a new radiator, thermostat, coolant sensor, o2 sensor, dizzy, sparkplugs, and wires.
Timing on my dizzy is adavanced all the way. If I retard it any the boging is even worse.
I only run high octane gas and my injectors all seem to be working fine.
If my timing was off would I get a code and also if my fuel pump is going bad how could I check that?
Old 06-16-2004, 06:36 AM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Definitly sounds like timing is off. And that wont necessarilly throw a code (it usually doesnt). Set everything to TDC and set the timing again, I bet it will run 100%.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 06-16-2004, 08:52 AM
1989_cash_eater's Avatar
1989_cash_eater 1989_cash_eater is offline
Re: Bogs
I had the EXACT same trouble with my D15B2. After trying all of the different stuff, the plug wires fixed it. It may also be a clogged cat. converter, or possibley water in your gas???
Anyway, after spending $140 to get a O2 sensor, for nothing, I am sure pissed. Good Luck with it.
"If you can read this...I'm Parked!..............Or broke down."
Old 06-16-2004, 12:29 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Re: My ZC bogs and sputters
sounds to me like the timing is off...the way you said if you retard the dizzy at all the bogging gets worse....i would 100% say it's the timing being off.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
