Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 06-16-2004, 03:04 AM
SelphSirv SelphSirv is offline
Send a message via ICQ to SelphSirv Send a message via AIM to SelphSirv Send a message via MSN to SelphSirv
Trans troubles
I'm looking at an RX7, forgot the year though.... I know its either fb or fc though. non turbo.... I'm most think first gen though, (unless first gens didnt have 13B's) thats why I posted here.
It has an automatic transmission. The guy says he thinks they burned it up becuase it drives slowly.
I wondering, is there something else that could cause this? Like could low fluid level? or something much more simple than a swap or rebuild.
And, if the trans is bad, where would I get a rebuild kit, or could get it rebuild in middle tennesse?
Any help would be greatly appreciated
Old 06-16-2004, 03:23 AM
Soyo's Avatar
Soyo Soyo is offline
Send a message via AIM to Soyo
Re: Trans troubles
http://www.rotaryresurrection.com/content.html
thats in tennessee
and the FB's had 12A's so I think your talking about a FC
1989 RX-7 TII --- Just got rebuilt and street ported
RB 3" dual exhaust, BNR stage 1 modified factory turbo, FCD, S-AFC II,
720cc secondaries, Aftermarket Turbo inlet duct w/K&N, Hawk HP+ pads
HKS Blow-Off Valve, Stainless brake and clutch lines
Old 06-16-2004, 03:44 AM
DevoutWankelist's Avatar
DevoutWankelist DevoutWankelist is offline
Send a message via ICQ to DevoutWankelist Send a message via AIM to DevoutWankelist
Re: Trans troubles
Just get a new transmission, it will be easier.
BAH!, went to change my sig and forgot what I was supposed to put here. . .
Old 06-16-2004, 05:06 AM
D3rELiC's Avatar
D3rELiC D3rELiC is offline
Re: Re: Trans troubles
thats in tennessee
again you are wrong,
mazda sold 13b EFI in some of the Fbs in 84-85
SelphSirv : i think you should look forward for a swap n/a parts are very comon and easy to find // install
the only things you need are the tranny, the clutch, flywheel, the 3 pedal set, the driving shaft (maybe, i dont know), shifter, starter, clutch master cylinder, clutch slave, clutch lines, some wirering mods and an ECU.
if you dont want to get into all this trouble, i suggest you to try to find another car, an auto rx7 sucks
Old 06-19-2004, 12:23 AM
Re: Trans troubles
Well.... I went back and paid attention for a few seconds.... and i feel like a fool. It is a fc, silly me.
Anyway..... I'll keep that place in kind. Does anyone know if whats wrong with it would have to include a rebuild in order to be fixed?
Old 06-19-2004, 02:01 AM
Soyo's Avatar
Re: Trans troubles
ask him if he ever drove it hard or took it about 5-6k rpms... if not the 5th and 6th ports cuz be frozen and that will lose you some power
Old 06-20-2004, 10:47 AM
drifting_FC3S drifting_FC3S is offline
Re: Trans troubles
is an automatic FB without the 13B, and a broken transmission even worth looking at still...find another car dude, without as many problems.
Old 06-20-2004, 02:19 PM
Soyo's Avatar
Re: Trans troubles
acctually, he said its an FC, so it has a 13B, and a tranny can be found farely easily for farely cheap if you look at junkyards around your area.. then if it needs a rebuild thats what will cost the most
Old 06-20-2004, 03:12 PM
MBTN's Avatar
MBTN MBTN is offline
Send a message via AIM to MBTN
Re: Trans troubles
FB's did come with 13B's in 84 & 85 IIRC.
