Old 06-16-2004, 01:07 AM
smokeymicpot smokeymicpot is offline
Send a message via AIM to smokeymicpot
help im trying to do a mpfi but i never get the right parts
every one tells me d motors can go together but i got a d15b2 puting a d16a6 head on it and intake and need a tb and found one last night for 50 on a d16z6 inake mainfold and win't to put it on the d16a6 one and no fit.. and i talk to some people and there like yeah it should go on soo am i wrong or are they wrong? and can i use the d16z6 intake i have allmost all of it? where can i get a tps honda says they dont sell them i was like what the hell? and im looking for is pm6 and disb for my swap if any one knows where to find them other than ebay?
Old 06-16-2004, 05:01 AM
Angry
no one knows how sad
Old 06-16-2004, 06:59 AM
Civic Jim's Avatar
Civic Jim Civic Jim is offline
Send a message via AIM to Civic Jim Send a message via MSN to Civic Jim
Re: help im trying to do a mpfi but i never get the right parts
you will have to leave it a while mate, a lot of people on here are from around the world so most people may be asleep, just give it a day or two and then you will get your answer
Jim - Your Resident EDM Biatch
B16A1 I/H/E
4TH GEN UK SITE
Honda Civic EE9 1.6-i VT
Old 06-16-2004, 08:27 AM
KoRnSaQ KoRnSaQ is offline
Send a message via Yahoo to KoRnSaQ
from my understanding, it should fit, but if it doesnt, it shouldn't be to hard to find a tb from an a6 engine
KoRnSaQ
Old 06-16-2004, 11:20 AM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
the z6 and y8 tb's are basically b-series tb's. They're interchangeable with b-series tb's not d-series...the bolt pattern is different. Just put on the y8 manifold...it's the best d-series manifold available.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 06-16-2004, 03:49 PM
soo can i put z6 manfold on a a6 head and what about it being off a vtec car dose that matter at all ?
i was thinking use the z6 manfold but siwtch out the injecter plugs on it for the low ohms and if that would would?
the only thing im missing is a part on the back right of it its got a screw there but thats it?
Old 06-16-2004, 04:09 PM
d16a6crx's Avatar
d16a6crx d16a6crx is offline
a z6 or y8 wont be a direct swap, they are OBD1 ad OBD2... so unless you do a conversion... unless you can use d16a6 sensors on the z6 or y8 manifold...can you?
1991 CRX Si
Looking for 88-91 Sedan or Hatch
Old 06-16-2004, 09:17 PM
91civicDXdude's Avatar
the only sensors that different from OBD generation is an oxygen sensor. TPS, IAT, MAP, etc. etc. DO NOT MATTER.
Use a z6/y8 intake and change out the fuel injectors and you are good to go.
Old 06-17-2004, 01:06 AM
oxygen sensor isn't that on the exhuast pipe any way im only puting a intake if it ison the intake where is it and on the z6 intake what is on the back right of it i only ahve a bolt am i missing something and dose any one know where there are some tps i can buy?
Old 06-17-2004, 10:53 AM
d16a6crx's Avatar
Re: Re: help im trying to do a mpfi but i never get the right parts
really? cool. thought you needed to change the tps and shit... oh well. Sorry about the wrong info
1991 CRX Si
Old 06-17-2004, 11:08 AM
ok i think i got every thing change over to teh z6 intake and was wanting to know for sure how many dif things should be on it like the tps map and stuff soo i can count it off and make sure its all there?
Old 06-17-2004, 11:12 AM
all the sensors are the same. the only difference (electronics wise) between the d16z6 manifold and d16a6 manifold is the D16Z6 manifold has the vacuum purge solenoid located on the back side of the manifold, and on our cars its located on the firewall. Also, the d16z6 throttle body has the map sensor mounted on it instead of on the firewall. I personally extended the vacuum purge solenoid wires, added a different plug (round, 2 pin plug, like IAT and others) and used the Z6 MAP sensor and purge, and removed that hideous setup from the firewall.
You, on the other hand, might choose to keep your firewall mounted map sensor and purge solenoid, and the car will not know the difference.
you *might* have to extend the IAT (intake air temperature sensor) wire since its located in a slightly different place on the z6 manifold. All of the plugs will be identical, though, except for that purge solenoid.
Old 06-17-2004, 07:42 PM
thanks for all your help its been great the only thing i have to assk is where is the purge on the intake and is there something on the back right side the side away from the tb there a pipe and than a bolt to teh right and there nothing there just making sure i got every thing? and whats the best way to take off my broken tps and put a new one on?
dose any one want 92 to 95 ex fuel injecters im selling them for liek 30 dollors for all 4 plus what ever shiping is
thanks again for all the help
Old 06-17-2004, 10:40 PM
BiGwiLLswiLLy BiGwiLLswiLLy is offline
Send a message via AIM to BiGwiLLswiLLy
if u still need a ecu i got a pg7 from a integra...more performance then the si ecu and plugs right in no mods needed
Old 06-18-2004, 12:23 AM
hey well that work with all this stuff a pg7 ecu work with si disb and all this stuff?
