Old 06-16-2004, 02:07 AM
cybercomm cybercomm is offline
Unhappy Car wont start
I have a honda accord (91?) 16V and it starts just fine when the weather is cold, but if i leave in the sun too long i am unable to start it. Does anyone have any ideas as to why this is happening? Clogged fuel or bad sens?
Also have to replace the head gasket (oil in coolant) as well (the car has 100K miles; ~160K KMs on it); and i want to know how hard is it, and if there are any special tricks?
Should i also rebuild engine or would new valves b ok?
Any other things i should do to it since im already "tunung" it?
Any help is greatly appriciated
Old 06-16-2004, 08:02 AM
Civic Jim's Avatar
Civic Jim Civic Jim is offline
Send a message via AIM to Civic Jim Send a message via MSN to Civic Jim
Re: Car wont start
well i wouldnt rebuild it if its only done 100k mate, and the headgasket is a big job if you dont know what your doing as well so i would take it to a garage,
you will need to change all the oil and coolant once the headgasket is done for good measure,
is the accord a carb or injection???
Jim - Your Resident EDM Biatch
B16A1 I/H/E
4TH GEN UK SITE
Honda Civic EE9 1.6-i VT
Old 06-16-2004, 12:25 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Re: Car wont start
could be the main relay.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 06-16-2004, 01:44 PM
viper_2_4's Avatar
viper_2_4 viper_2_4 is offline
Send a message via MSN to viper_2_4
Re: Car wont start
ya, sounds like the main relay to me, since you said it won't start if you leave it in the sun...
Old 06-16-2004, 01:46 PM
Fewman Fewman is offline
Send a message via AIM to Fewman
Re: Car wont start
The accord forum might know a little more about accords too....
Old 06-16-2004, 07:10 PM
Talking Sorry its not accord :)
not accord, i was just lookin at my buddys accord, its a hoda civic CRX, and yes it does have a carb, (although i dont know weather it is one of those carbs with the injector in it).
I have the haynes manual, and it lists how to do the gasket, i guess i have to ask what kind of gasket sealant should i use (RTV?; black?)
PS Where exactly is the main relay located?
THANKS FOR YOUR HELP!!
Old 06-17-2004, 01:58 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
why you using gasket sealant ? i hope its not for the headgasket. use a oem honda head gasket not sealant shit.
take out your coin tray and look to the left, you should see it
Team Lonely Drivers
Old 06-17-2004, 04:33 AM
Re: Car wont start
aaah i was just readin on that actually the OEM one has aluminum insers or something.. so then i dont need sealant?
do i also need some o rings for the oil pipe that goes to valve cover?
PS someone PMed me this site it is perfect, it tells exactly how wand where you can change relay
http://www.crxsi.com/resources/repai...ng_main_relay/
