Go Back   Automotive Forums Car Chat > Honda > Integra
Old 06-15-2004, 11:39 PM
Patrix Patrix is offline
Send a message via AIM to Patrix
How do you adjust KYB AGX shocks?
and how easy are they to adjust on a teg with about a 1.3" drop?
thanks
Old 06-17-2004, 10:42 PM
loesch8102's Avatar
loesch8102 loesch8102 is offline
Send a message via AIM to loesch8102
Re: How do you adjust KYB AGX shocks?
When installed, a small dial sticks up out of the shock tower under the hood and in the trunk. With the supplied screw driver you press down lightly and turn. When the white dot is over the number you want, let go. 4 is the stiffest, 1 is the softest. Takes about a minute, if that.
Old 06-21-2004, 12:02 AM
wow. that sounds a lot easier than I expected. thanks
Old 06-27-2004, 06:07 AM
loesch8102's Avatar
No problem...Glad I could help.
Old 10-16-2008, 07:24 PM
chocolate_supra chocolate_supra is offline
loesch8102,
I realize it's been years since the last reply in this forum, but I have a question about the adjustment, as well. I just got a set in for my Supra, and the stickers on the top that show the numbers are mostly worn off. I can read one, and barely read the other three. Thing is, when you align the paint marks on the top of the shocks, the adjustment dots for the front are facing exactly opposite from each other, and same with the rear. Is it supposed to be this way? Thanks!
