Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 06-15-2004, 10:49 PM
TurboSW's Avatar
TurboSW TurboSW is offline
Will 99 Ram head lights fit on a 96 Ram? Mine are yellowed.
Hi guys, I thought maybe someone could help me out with this question. My 96 Ram head light lens are yellowed and the light really doesn't shine through. I was thinking about replacing them, but If the newer clear style from 99- 02 work I'd like to use those. Any help would be appreciated.
Old 06-16-2004, 06:36 PM
TurboSW's Avatar
Re: Will 99 Ram head lights fit on a 96 Ram? Mine are yellowed.
Has anyone's 96 Ram head lights turned yellow?
Old 06-16-2004, 06:58 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
They fit.
My Mopars
Old 06-16-2004, 08:02 PM
TurboSW's Avatar
Thanks. I found that out today from a dealer. I was very happy to hear that, but then I found out that the 99 head lights have 2 bulbs per head and as we all know 96 only has 1 per head light. now that seems to be a big problem. How do I connect the 2nd bulb?
Old 06-16-2004, 11:44 PM
BleedDodge's Avatar
Just purchase the appropriate head lights.
My Mopars
Old 06-17-2004, 12:18 AM
TurboSW's Avatar
I know what you mean, but the 99 head lights look better than the 96. The 99 sport version has the clear lens.
Old 06-17-2004, 01:26 AM
BleedDodge's Avatar
I never noticed...
My Mopars
Old 06-17-2004, 07:47 AM
slantsixness's Avatar
slantsixness slantsixness is offline
Buy the connectors and wire them up. If you can't, then go strip the front lighting harness out of a junkyard.
(but I'd hate to see a '99 in a JY, it'd have to be really F#$&ed up)
If I knew what I did to break it, I would've known not to do what I did.
www.classicwinnebago.com
Old 07-27-2004, 07:16 PM
sharpdodge sharpdodge is offline
I'm as new as they come and I hope this is going to the right spot - We have a '95 Dodge show truck. I decided the '99 Sport duel headlights would look real sweet in the truck. I was told by my suplier that they would fit right in. This was the start of all the problems. I finally got them installed by taking a 4" hole saw and cutting through the sheet metal behind the headlight to accomodate the second bulb. It fit good and it looked good. Now coming home one evening from a car show, I could smell wires burning so I pulled the dash panel off to check the headlight switch, the headlight switch and the wiring was burnt. I found out that the '95 Dodge had a problem in that area anyway and that it could not handle the extra electrical draw. Four relays and miles of wire finally solved the problem, I'm running a direct fuse wire from the battery to the relays and activating them with the dimmer switch. If I had it to do again, I wouldn't. You should be able to find a set of lights at the salvage yard at a reasonable price.
SharpDodge.
Old 07-27-2004, 07:22 PM
TurboSW's Avatar
SharpDodge.
Wow, sounded like a hassle. It's too late for me to try it because I bought a new standard head lamp. I really wanted to do it though. BTW what does the relay do and where did you put them and the extra wiring? Oh and where did you get the extra bulb harnesses? I wish you would have posted sooner.
Thanks though!
Old 07-28-2004, 02:04 AM
BleedDodge's Avatar
It sounds like you need a new truck, TurboSW. You're putting newer style headlights and everything on from a newer truck, and 20 inch pimp dubs from a newer truck on, on a 1996 truck. I don't get why you don't just sell this thing and get the truck you want, instead of putting everything on an older truck. I know that's just my opinion, but you're asking for advice anyways so you don't need to get mad at me over this. I'm not trying to offend you.
My Mopars
Old 07-28-2004, 08:15 AM
TurboSW's Avatar
Wanting new head lights and different wheels warrants a new truck? One I don't want payments and 2, I love my truck. In fact I like the style better that the 05's. Now if I could get a Viper truck, that would be a different story.
BTW, I wasn't asking for your advise on how and what I should do to my truck. I asked how to fix things on my truck and your remakes are totaly useless. For example, the wheel stud problem I had.
Old 07-28-2004, 03:45 PM
BleedDodge's Avatar
Sorry guy.
My Mopars
