Old 06-15-2004, 07:50 PM
Hotcupl98632 Hotcupl98632 is offline
Send a message via AIM to Hotcupl98632 Send a message via Yahoo to Hotcupl98632
What is the difference d15b and d15b2
Hello,
We ordered an engine for our 91 Civic DX - it was supposed to be identical to the one we took out d15b, however, when we recieved it, it was the d15b2. There is some sort of breathing apparatus going into the head - next to the distributor just above the thermostat housing, (this isn't on old block, there is an outline in the casting but it was not punched out) what do I hook this up to. New engine has a dual carb setup (the old has dual point fuel injection, which I prefer to use) and the new engine was setup for an automatic tranny (I have manual 5 speed). What is the diffence (other than what I mentioned) between the 2 engines and will we need to change anything? I saw some previous posts, but they didn't really answer my specific question.
Thanks in advance.
Susie
Old 06-15-2004, 07:58 PM
Oops
OOPS,
Okay, sorry "guys" the engine we took out is the d15b2, the engine we are putting in is the d15b.
Thanks again,
Susie
Old 06-16-2004, 12:41 AM
nemo_wolf's Avatar
nemo_wolf nemo_wolf is offline
Send a message via AIM to nemo_wolf Send a message via MSN to nemo_wolf Send a message via Yahoo to nemo_wolf
Re: What is the difference d15b and d15b2
well im not much on the engine swap knowledge but i dont think you will need to do much for the tranny as the manual and auto should have the same bolt pattern. as for the dual carb to DPFI ... well im gonna guess again that the bolt pattern is the same so try fitting it in.
uhhh i hope that helps.
AF Bay Area Crew
91 civic LX sedan : Dec. 3rd 01 - Dec. 9th 02
88 civic DX hatch : Jan 14th 03 - Oct 05
96 Zamboni Model 552 : done working there
00 Civic EX coupe : Oct 05 - Sept 2010
11 Scion xB : Sept 2010 - Present
Old 06-16-2004, 03:01 AM
pisetup's Avatar
pisetup pisetup is offline
Send a message via AIM to pisetup
The D15B is JDM, it's from a Civic VTi, I think.
- joe
Old 06-16-2004, 08:32 AM
KoRnSaQ KoRnSaQ is offline
Send a message via Yahoo to KoRnSaQ
ya, you should be able to just switch out the tranny,( your new one with the old), I am not sure what you will have to do to switch the carbs with the DPFI.
KoRnSaQ
Old 06-16-2004, 09:20 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
well hopefully you can just use the dpfi setup from the old motor, the tranny should just bolt together with no problems, although im thinking you may have to change the shift linkage. anyway good luck with it.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
