Go Back   Automotive Forums Car Chat > Pontiac > General Discussion
Old 06-15-2004, 07:43 PM
hopeless4life hopeless4life is offline
Send a message via MSN to hopeless4life
Most Reliable Pontiac Engine
What Is the most reliable pontiac engine? Don't say 2.2L cause thats what i'm swappin out
Old 06-17-2004, 12:57 PM
landyacht's Avatar
landyacht landyacht is offline
I believe the 3.8L V6 is the best motor that Pontiac has...especially the supercharged version.
Mine's an '82 Pontiac Parisienne 4-door sedan!!
- 305 cu inch (5.0L) small block V8 w/ 3spd auto
- 4 barrel carb w/ single exhaust
- No catalytic converter, no posi-trac
NEVER LOSE FAITH IN THE BOAT!!
Old 06-17-2004, 12:59 PM
CarSuperfreak's Avatar
CarSuperfreak CarSuperfreak is offline
Send a message via AIM to CarSuperfreak
Re: Most Reliable Pontiac Engine
Id say nonsupercharged is more reliable; fewer things to go wrong (although i do like the s/c one better)
but best all-time has to be the LS1/LT1 (you can't beat a 350, its about bulletproof)
but if youre swapping out a 2.2, i doubt a 350 would fit. go with a 3800 or 3800 s/c
I do not feel obliged to believe that the same God who has endowed us with sense, reason, and intellect has intended us to forgo their use.
- Galileo Galilei
Old 06-18-2004, 11:01 AM
brianneves brianneves is offline
the pontiac 400 small block is practically indestructable and my personal experience says that one will still run strongly with half the cylenders at 75 to 85% compression and the other half under 50% compression, but i dont think that its practical for your application
Old 06-18-2004, 11:02 AM
go for the 3.8. its reliable and powerful. easily modded and SUPERCHARGED!
Old 07-30-2004, 09:48 PM
leadfootGTP's Avatar
leadfootGTP leadfootGTP is offline
its only supercharged on grand pri gtps and the new monte carlo ss' and some bonnevilles i think, mabe a couple others, but most of the 3800s are naturally aspirated
Old 08-15-2004, 11:59 AM
Robbie1's Avatar
Robbie1 Robbie1 is offline
The regal gs has a supercharged engine.
If you wanna see what available for 3800sc parts go to:
http://www.3800performance.com/index.html
If you want to put one in your car check out this:
http://www.cardomain.com/memberpage/526752
Hope you have lots of money. I wanted to do it, and it would be cheaper to buy a Grandam ect.
Best of luck whatever you decide.
Old 01-07-2005, 06:39 PM
inlineguy inlineguy is offline
a pontiac 400 but that wont work in your situation.
Old 04-11-2005, 02:30 PM
ltbuick ltbuick is offline
3.8 not pontiac
the 3.8 is a buick design from way back. this was the most powerful and fuel economical engine GM could offer.
