Old 06-15-2004, 04:57 PM
91redmr2turbo 91redmr2turbo is offline
Question torque specs
does anyone know some torque spec on putting an axel nut on and on lug nuts. and this maybe a dumb question how do you tell how much torque is being used by the gun at once?the max torque of the gun is 230lbs and my tank goes up to 200psi
Old 06-15-2004, 06:27 PM
red4thgencivic's Avatar
red4thgencivic red4thgencivic is offline
Send a message via AIM to red4thgencivic
I usually just run my axel nuts all the way down with a 1/2" drive impact wrench at 200 psi on the compressor. When it's tight the nut should be near or past flush with the end of the axle, make sure you punch it.
As for lug nuts, i never ever ever let anyone use an impact wrench on my lugs. I didn't pay 50 bucks for nice mcguard lockers just for some monkey with an air hose and a gun to tear them up(but i guess that's why my car never sees a garage other than mine). I simply use a 4 way lug wrench and tighten them as tight as i can, never had a problem with loose lugs.
Why can't money come easier?
ok so i had two civic hatchbacks, i totaled one because i wasn't paying attention, the other one i got ran into a creek by an old lady asleep at the wheel, then i got a CRX was being retarded hit a deer at 90 and flipped, so now i drive a 1992 celica GT and i love it, done with being stupid, this one will not be wrecked.
Old 06-15-2004, 06:33 PM
dfarres's Avatar
dfarres dfarres is offline
Send a message via Yahoo to dfarres
Re: torque specs
i believe the axle nut should be at 135lbs and the typical lug nut is around 80lbs. and don't use a gun for either, use a torque wrench.
1993 Civic Coupe EX
1997 Chevy Suburban LT
“It's all fun and games - Until someone loses an eye"
Old 06-15-2004, 08:36 PM
Re: torque specs
ok thanks guys
Old 06-15-2004, 09:37 PM
BullShifter's Avatar
Re: torque specs
Find all torque spec's in the manual - http://www.binghamtonlife.com/manual/2gsm/default.htm or buy one from www.helminc.com
