Old 06-15-2004, 04:55 PM
Tonyr's Avatar
Tonyr Tonyr is offline
Cruise failure
Has anyone had a problem with their cruise control just shutting off while on the highway? It's happened about 4-5 times to me intermittently. I just shut it off and start it again and it's OK.
Old 06-15-2004, 10:30 PM
rubberman rubberman is offline
my cruise control doesnt themajority of the time. If it does then its a miracle. I did notice that when it does work it will shut off within 5 secconds. Curious to know what i need to do to fix it? hopefully not too expensive
2000 Grand Prix GT w/ gold package.
K&N CAI intake, U bend delete, ZZP PCM, Ractive oval exhaust tips, ZZP 3" downpipe
2004 Chevy Trailblazer EXT
Keep on Keeping on...
Old 06-16-2004, 07:23 AM
cayton69 cayton69 is offline
does it just shut off, or are you turning your wipers on or off when it shuts off? mine will sometimes shut off if i'm fiddling with the wipers. it's a tsb i do believe.
Old 06-16-2004, 07:32 AM
Re: Cruise failure
no it shuts off by itself without touching the wipers. I can be cruising down the highway and set the cruise (when it does work), put my hands on the steering wheel and within 5 seconds it shuts off. Then i can reset it but it will shut off again in 5 secs. its a pisser
Old 07-07-2004, 07:34 PM
candywrapper candywrapper is offline
I have a 91 grand prix gt, my mechanic told me that thier is a cruise control switch down by your brake pedal. mine had to be replaced.when you hit your brakes it kicks off your cruise control,that switch might be bad Don
Old 07-10-2009, 05:55 PM
1 x navyguy 1 x navyguy is offline
Re: Cruise failure
mine will sometimes shut off if i'm using the button to increase speed...but it only does it if i'm bumping it up to 70-72 or so...after i get past that speed it don't seem to be a problem.
Old 07-11-2009, 01:01 AM
doctorhrdware doctorhrdware is offline
Re: Cruise failure
Tonyr, year, engine and mileage. I have a 97 GP SE and have no problems with the cruse control like you are having. Mine will even work at 30 mph also, which it should not do that.
Old 08-19-2011, 08:25 AM
Stormin-Norman Stormin-Norman is offline
Send a message via MSN to Stormin-Norman
Re: Cruise failure
We have a 2001 Grand Prix SE, our cruise will work fine on a level highway or while going up a hill but it will shut off when it starts down a hill (any time the throttle returns to the idle position), if I maintain just a slight amount of pressure on the gas pedal it will work fine. I replace the module yesterday & it still does the same thing, any ideas.
Old 08-19-2011, 06:39 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Re: Cruise failure
I don't think your car has a problem as that's the way the cruise control is designed to work.
It's supposed to maintain a constant speed. When you're driving on flat surface will give the pedal a slight push one at a time until the speed is reached.
When going uphill it will open the throttle a little more (as it needs a bigger effort to maintain speed) and that normally causes a lower fuel economy.
Finally when going downhill the car tends to increase the speed on it's own because of gravity; that's why the cruise control releases the throttle and turns off.
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 08-20-2011, 01:48 PM
Tech II Tech II is offline
Re: Cruise failure
I would check the brake pedal switch....could be just out of adjustment...
Old 08-21-2011, 10:42 PM
mrrdeac mrrdeac is offline
Re: Cruise failure
I had a similar problem on my 2002 GP. After a little research, I was led to the multifunction switch on the steering column. This is a combo with the turn signal, wipers, and hazard lights. Turns out that if the hazard light contacts are bad, the cruise control will not work. The multifunction switch is very expensive. All I had to do was push on the hazard light button a couple of times and "bingo" the cruise started working again. I have also read that the 3rd brake light (center) can keep cruise from working (not my experience though)
