Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 06-15-2004, 03:54 PM
Akshay Akshay is offline
setting timing on '97 Sierra 350
How do I check the timing on a 1997 Sierra z71 w/ 350?
Where is the adjustment screw on the distributor?
Thanks.
Old 06-15-2004, 04:22 PM
Jeremy-WI Jeremy-WI is offline
Re: setting timing on '97 Sierra 350
You don't adjust timing on a 97. If the SES isn't on for a P1345 your timing is good enough to run.
If you do want to check it you need a scantool that will display cam retard or camshaft offset. On a V8 it should be 0 degrees +/- 2 degrees
