Old 06-15-2004, 12:37 PM
sticks sticks is offline
2 quick questions
hello, i drive a 97 2.2l cavy ss, and first was wondering about my stereo. it's aftermarket and since i replaced my rear 6x9s, sometimes at higher volumes the cd player seems to shut itself off then turn back on. any ideas on what could be causing this? first i thought maybe vibrations from the speakers but i don't think it's that bad (i don't have subs but i still get a good kick). maybe a loose connection?
second, it's not that big a problem but it's been bugging me. in the morning dew on my car the last few days, i've noticed an unsettling word on my roof. at first i thought someone was writing it every morning before i left for work, but it happened last night after it rained as well. looking at the car in sunlight shows no scratches shaped like the word, it's only after rain or in the morning dew. is it possibly some sort of oil or grease staying on there? and any suggestions on removing it?
thanks.
Old 06-15-2004, 03:45 PM
STINKINLINCOLN's Avatar
STINKINLINCOLN STINKINLINCOLN is offline
Send a message via AIM to STINKINLINCOLN Send a message via MSN to STINKINLINCOLN Send a message via Yahoo to STINKINLINCOLN
Re: 2 quick questions
does your whole deck shut off then go back on?
did you put the deck in yourself ?
well it sounds like maybe you have a loose wire
ground are postive wire you mite be arking out when you hit a bump are somthing
do you have a amp ?
are a power wire that runs from the battery to the
amp ?
as for the second problem It sounds like your right about the grease
give it a good wash then wax it see if it is still there ?
93" LINCOLN CONTINENTAL
69" BUICK RIVIERA
1988 MAZDA B2200NEEDS HELP
http://www.geocities.com/jjbannon81/69RIVIERA.html
1999 OLD ALERO
Old 06-16-2004, 02:08 PM
angel_iz378 angel_iz378 is offline
Send a message via MSN to angel_iz378
i have the same prob with a grafix that i recently replaced. when the window is wet and at certain angles u can still tell where the old one used to be
I love humanity. It's people I can't stand.-Gil Grissom
Check out My NEW 2007 Cobalt LT "Pheonix" @ Car Domain
