Old 06-15-2004, 12:12 PM
Chopper-boyz Chopper-boyz is offline
'92 LeSabre A/C-heater controls
I have a 92 LeSabre that when I change from heat, vent defrost, A/C the direction of the air flowing does not change. If I change from heat to A/C, the A/C does come on but it just does not flow out the correct vents in the dash. I believe the door or flap that diverts the air to the different vents is not moving. I am assuming its somehow controlled by vacuum.. or a electrical vacuum operated switch but I cannot find any fuses blown or anything else wrong.
Anyone have any clues??
Thanks
Chopper-boyz
Old 06-15-2004, 12:34 PM
Jed Rule Jed Rule is offline
Re: '92 LeSabre A/C-heater controls
Does your cruise control work? If not you have lost the vacume feed into the car. The vacume feed comes off the back of the intake to a tee by the vacume tank on the firewall. Check for cracked or loose lines.
Old 06-21-2004, 05:53 AM
Jed Rule,
Thanks for the information, you were dead on.... while the cruise control still worked, I looked in the general area and found a vacuum line disconnected from a port on the firewall. It must have came off when I changed out the plug wires a few weeks ago.
Chopper-boyz
Old 06-21-2004, 06:01 PM
HEY, I guessed right again.
