Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 06-15-2004, 11:58 AM
danford1 danford1 is offline
Moan and groan while idling and turning off engine
I have a 91 with a 5.0 HO engine.
It makes a constant howl, or moan while idling. Then when the engine is turned off it makes a louder groan until it stops turning.
I tried unhooking the air pump hose, no differnece, I replace the intake gaskets because of a bad oil leak. I was hoping that would also cure the moan, it didn't faze it.
It is coming out of the throttle body/intake area. If I unhook the air cleaner cover and take out the air filter, it gets very loud. The air box is muffling the sound.
Any ideas?
The engine runs fine otherwise. Starts right up, runs smooth, lots of power etc.
Danford1
Old 06-15-2004, 05:28 PM
flewthecoupe's Avatar
flewthecoupe flewthecoupe is offline
Re: Moan and groan while idling and turning off engine
Replaced the intake gaskets or the valve cover gaskets?
It's not how fast you can go, it's how fast you can get there.
Proper grammar, it's not just for English teachers.
I don't pick on any one person, I treat everyone this way.
My only pleasure is tormenting those people who work for me.
There are no stupid questions, just a lot of inquisitive idiots.
Old 06-15-2004, 08:49 PM
Re: Re: Moan and groan while idling and turning off engine
I replaced the intake gaskets. The rear POS cork gasket was broken and was letting oil out all over the bell housing.
I never use those end gaskets. I always just run beads of silicon on both the intake and block, let it set up 15-20 minutes and install. That doesn't leak !
