Old 06-15-2004, 11:27 AM
dazza7's Avatar
dazza7 dazza7 is offline
Exclamation Need some help with a 97 Civic Driver side Fender***
Iv got a Bigish dent on the drivers side Fender (RHD). I tried the bathroom plunger thing to pull it out and it just made the dent worse. I need some information on how to remove the Driver side fender (My car is UK spec RHD). All links and url's etc are appreciated. If any one has any experience on pulling out dents thats would be good. Thanks.
Old 06-15-2004, 11:30 AM
emerge's Avatar
emerge emerge is offline
Send a message via AIM to emerge Send a message via Yahoo to emerge
Re: Need some help with a 97 Civic Driver side Wing***
bathroom suction thing? a plunger? I'm not sure what part of the body you mean by wing.
Stephen Gladney
Original PH Member
EJ8 Civic | AIM: nxzo | www.rtek.org
Old 06-15-2004, 11:32 AM
dazza7's Avatar
hi m8. can you see the black civic pic in ur profile on the right. Look at the left front light and its the wing which connects to the light (z3 fenders would normally replace this wing), its above the side indicator light.
Old 06-15-2004, 11:34 AM
emerge's Avatar
Oh. Hmmmm....I would call a dent removal company. I had a dent in my stock hood and I tried to take it out myself and only made it worse.
kicker may know, he does body work
Stephen Gladney
Original PH Member
Old 06-15-2004, 11:36 AM
dazza7's Avatar
i need some instructions on how to take the wing off and it shud b ok from there on
Old 06-15-2004, 11:41 AM
emerge's Avatar
I can tell you how to take off the whole fender.
Stephen Gladney
Original PH Member
Old 06-15-2004, 11:51 AM
dazza7's Avatar
hi m8. Yeh sorry for confusing you its the Driver side fender, im from the uk though so its on the right side (RHD). That would be great if you could. Do you have any instructions?
Old 06-15-2004, 01:21 PM
lkailburn's Avatar
lkailburn lkailburn is offline
Send a message via AIM to lkailburn
its not a wing! its a front right/left fender, or front right/left quarter panel.. wing is what you would call the big tacky thing ricer's slap on their trunk
Old 06-15-2004, 02:38 PM
emerge's Avatar
Aiight, here's how to take off the fender. I had to do this a week ago to install my 99-00 fenders...
There are a total of 6 bolts.
1. Pop the hood. Along the top of the fender and the wall of the engine bay, there will be three bolts holding the fender on. Loosen these, but don't totally unscrew them.
2. Look in your wheel well at the front of your sideskirt. There will be one screw holding the front of the skirt on. Unscrew this. Un-snap about 1-2 of the plastic holders on the sideskirt to give you some working room undernead the skirt. Pull the skirt off a little bit in the front.
3. There will be two more bolts underneath the side of sideskirt (where the skirt meets the fender). Unscrew both of these and take them out fully. (DONT LOSE THEM)
4. Open your door. There will be one more bolt on the inside of the frame where your door hinges are. It's a little tough to get to, but with the right tools, it can be done. Unscrew this bolt and keep it with the other two.
5. Go back to three bolts in the engine bay. Take of the two outer ones first and then the middle one. Slowly pull the fender off the car.
That's it. Good luck!
Stephen Gladney
Original PH Member
Old 06-16-2004, 05:49 AM
dazza7's Avatar
Thumbs up
Thanks a lot emrge for your help. Im gona try taking it off today. Ill pos to see whether i could take it off.
Old 06-16-2004, 07:34 AM
lkailburn's Avatar
^^^ just curious.. why so picky with the top bolts?
Old 06-16-2004, 11:57 AM
emerge's Avatar
Because if you take them off first like I did, when you get that last bolt off, your fender falls on your head...
Stephen Gladney
Original PH Member
Old 06-16-2004, 12:01 PM
alphalanos alphalanos is offline
hehehe
96 EJ6. Future home of boosted B18C1.
Old 06-16-2004, 12:37 PM
dazza7's Avatar
Thumbs up
thanks a lot emerge for the instructions. Iv got a 97 ek3 so it had about another 3 bolts on the front of the fender near the headlamp. i managed to push the dent out.
Thanks.
Old 06-16-2004, 01:32 PM
lkailburn's Avatar
Re: Re: Need some help with a 97 Civic Driver side Wing***
ahhah well thanks for the tip then
