Old 06-15-2004, 08:24 AM
1989_cash_eater's Avatar
1989_cash_eater 1989_cash_eater is offline
Re: Revs Kinda Weird???
It seems that when it's hot out, the cars idle will be anywhere between 1400-2200 rpm.
Does anyone know what causes this??? I know that when I pop the hood and press the trottle back it goes to normal rpms until I rev the car up again.
Help me please. This really pisses me off!
Thanks
"If you can read this...I'm Parked!..............Or broke down."
Old 06-15-2004, 08:33 AM
Civic Jim's Avatar
Civic Jim Civic Jim is offline
Send a message via AIM to Civic Jim Send a message via MSN to Civic Jim
Re: Re: Revs Kinda Weird???
sticky throttle cable , lube it up, if not spray some injector cleaner in throught the iinlet, there maybe some shit inside, i expect theres more things too
Jim - Your Resident EDM Biatch
B16A1 I/H/E
4TH GEN UK SITE
Honda Civic EE9 1.6-i VT
Old 06-15-2004, 10:01 AM
red4thgencivic's Avatar
red4thgencivic red4thgencivic is offline
Send a message via AIM to red4thgencivic
It could be alot of things. Check the cable first, that's easy, if it's too bad just to put some grease on, then a new one from honda is only like 15 bucks, i've bought like 2 of them from the dealership locally But they only ship on thursdays here and they'll charge you 15 bucks for next day shipment so you gotta make sure you tell them you just want to wait till thursday.
Also i had this problem when i got my DX crx that had been sitting for 2 years, there were three vacum lines that came together in a T shaped fitting to the passenger side of the throttle body, turns out one of them was cracked and would cause the motor to idle at 2,000. I'm sure you can get the hose somewhere but i just happened to have some that fit. It's really small. Like 1/4" outside diameter or less.
just some possibilities...
Why can't money come easier?
ok so i had two civic hatchbacks, i totaled one because i wasn't paying attention, the other one i got ran into a creek by an old lady asleep at the wheel, then i got a CRX was being retarded hit a deer at 90 and flipped, so now i drive a 1992 celica GT and i love it, done with being stupid, this one will not be wrecked.
Old 06-16-2004, 07:49 AM
Re: 'DA CAR
How do I know if the trottle cable is damaged???
Old 06-16-2004, 07:51 AM
Civic Jim's Avatar
the easiest thing to do is gut a buddy to sit inside and then push the throttle to the floor and then off again (without the engine running) then you can see if the throttle cable is sticking and not returning back to its proper idle position, just a thought
B16A1 I/H/E
4TH GEN UK SITE
