Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 06-15-2004, 04:05 AM
Dbaird99 Dbaird99 is offline
Bad acceleration after Rodeo is warm.
Hey,
I am having a problem with acceleration after the 1994 V6 Rodeo has warmed up. I step on the gas and the RPM go high but I get no acceleration. If I feather the pedal it does a little better, but I still can't get up the slightest hill, it is usually just enough power to get me home.
I just had a tune up done that included the plugs and plug wires, so it's not that. I also had the clutch replaced last year. I have just replaced the O2 sensor (which is what everyone said was the problem). I had the timing belt replaced last year as well. I get no check engine light or trouble codes. The other strange part is that I am trying to get it registered and it won't pass the I/M test because once they get the engine hot the h/c's jump ALL over the place. Normal is 220 I think and mine is ranging from 50 to 1200 at times! and this only happenes when it is warm (this makes me think it is a sensor, but which one?)
Any other ideas as to what could be causing the problem? Please help.
Thanks,
-Dustin
Old 06-15-2004, 04:25 AM
rodeo02 rodeo02 is offline
Check/clean/replace your mass air flow sensor.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 06-15-2004, 12:35 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: Bad acceleration after Rodeo is warm.
Check to see if your cat converter is plugged.
-Ryan
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
