Old 06-15-2004, 03:56 AM
ddrcrew ddrcrew is offline
Unhappy 95 trans am auto past redline and does not shift
Hello all i have a 95 trans am, it is an auto. When I use it and i push the accelerator at "full" the 2 gear pass the 3 gear pass but when the car want to go into 4 gear it pass the redline and won't shift the four gear i must remove my foot on the accelerator so that the car go into 4 gear.
After that my car is unable to go into 1 st gear it stay at 2 nd gear when i force the 1 st gear the car stay in 2nd gear i must cut off the contact and restart to go into normal shift and when i drive normally the car shift well 1 2 3 4 normally please can you help me ? have you any suggestion
Excuse for my little english i'm french the car is not an european version it came from usa
Old 06-15-2004, 12:12 PM
FirebirdChris FirebirdChris is offline
Send a message via AIM to FirebirdChris Send a message via MSN to FirebirdChris
Re: 95 trans am auto past redline and does not shift
About a year ago my firebird yet only a V-6 acted similar. I would start it up and take off after passing 2nd gear it and into third it would not go into 4th no matter how fast i went. I took it into my mechanic and he replaced a transmission default solenid. 10,000 miles later it did it again and he had to do some rewiring he said but all said and dont it ran less than 400 for both times i took it in. My service engine light was also on at the time and my car is a 96
Old 06-15-2004, 12:35 PM
Re: Re: 95 trans am auto past redline and does not shift
Thank you for your contribution if another person have the same problem and how to resolve it please post.
One more time thank' a lot firebirdchris
Old 06-17-2004, 08:13 AM
Re: Re: Re: 95 trans am auto past redline and does not shift
just to go up !
Old 06-17-2004, 01:29 PM
DVS LT1 DVS LT1 is offline
Are you in drive? "D" - because the car will not shift past 3rd in "D", just as it will not shift past 2nd gear with the shifter in the "2" position or first gear in with it in "1".
If you've got it in overdrive "OD" then it will shift up to 4th ("OD" is 4th).
Old 06-17-2004, 02:00 PM
Hello i drive in "D" mode no problemo thank you for your contribution
Old 06-17-2004, 02:04 PM
Me too - I only shift into OD on the highway, or when I race. launch in D off the line and into second (or third) - just remember to bump the shifter up into OD before you run out 3rd - I've forgot to do that once and started bouncing off the rev limiter.
Eh, so whats it like to drive a Firebird in Europe?? get any good looks at your car?
aur revoir
Old 06-17-2004, 02:07 PM
CarSuperfreak's Avatar
CarSuperfreak CarSuperfreak is offline
Send a message via AIM to CarSuperfreak
just had to have some selenoids replaced on my car because it was starting in 2nd gear, and wouldnt start in first. selenoids seem to go all too often
I do not feel obliged to believe that the same God who has endowed us with sense, reason, and intellect has intended us to forgo their use.
- Galileo Galilei
Old 06-17-2004, 02:23 PM
aur revoir
i post the photos of my bird in this topic but i don't understand why the car does not shift correctly when you push the accelerator at max
Old 06-17-2004, 02:36 PM
here is the photos this is a trans am convertible interior red and black
Old 06-17-2004, 02:46 PM
[quote=ddrcrew]here is the photos this is a trans am convertible interior red and black
here is the photos
http://files.automotiveforums.com/ga...hp?photo=20422
http://files.automotiveforums.com/ga...hp?photo=20420
Old 06-17-2004, 02:54 PM
use the edit/delete on the bottom of your posts, no need to make 3 separate posts in a row
- Galileo Galilei
