Hey, whenever i turn on my headlights my fog lights, instrument cluster, and taillights don't light up! I have a 97 elantra SE.
My brake lights still light up when i press the brake pedal and my headlights still work fine. I checked all of the fuses and it's driving me nuts because i have no idea what is wrong.....ANY help would be greatly appreciated!!!
SURGEON GENERAL SAYS:It's ok to smoke V8's. NEW PROJECT! CAMOUFLAGE CIVIC PROJECT MECP FIRST CLASS CERTIFIED INSTALLER |
Re: help with taillights, instrument cluster and fog lights!
Have you checked your tailights with a DVM to see if there is any juice getting through to your tails while your headlights are on?
did you check both fuse boxes? the one in the car, and the one in the engine bay?
If his brakelights work but not the running lights this is not a fuse issue. However if the 97 used a double pole relay one of the contacts maybe damaged. It very well could be just a burnt out primary filiment in the bulb or a shorted line for the primary, since it took out his dash lights too. That's why it is important to establish if there is a potential present.
Jason Last edited by nippjas; 07-01-2004 at 12:26 PM. |
well thanks for the help guys.....i figured it would be a relay so i checked the fuse box under the hood and swapped the horn relay with the TAIL1 realay.....and the lights all worked fine! The best part is the horn works too! so i don't know if it was just loose or something.....anyways problem fixed and thanks again.
Jason Last edited by nippjas; 07-01-2004 at 12:25 PM. |
