Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 06-14-2004, 11:35 PM
KaMaKaZiPyRo KaMaKaZiPyRo is offline
Send a message via AIM to KaMaKaZiPyRo
Custom or Kit Turbos?
Wich one would be a better setup for a daily driver, which one would be able to have more power and which one would be able to hold longer?
Currently trying to piece together a Turbo CrVtec bubble hatch, expecting sumthin like 500hp?!?!?!
Old 06-15-2004, 12:00 AM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
Re: Custom or Kit Turbos?
custom will always make more power and be cheaper than a set kit... how reliable it is depends on how well you put it together and the quality of the components you use, if you're lazy and don't know much about turbo's and stuff, get a kit and get it professionally installed
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Old 06-15-2004, 01:39 PM
Alrite, but I heard sumthing about only one of them, custom or kit, would be able to use the boost contoller or be able to be increased or tuned or w/e i forgot maybe sumone knows what im talkin about.
Old 06-15-2004, 01:50 PM
Beyond Imagination's Avatar
Beyond Imagination Beyond Imagination is offline
you can use a boost controller with custom OR kit
88 Honda CRX Si - B16
90 Honda CRX Si - B20VTEC
Old 06-15-2004, 01:56 PM
YellowITR479 YellowITR479 is offline
hehe...i'd let a pro take it from here
1996 GSR w/ 1995 OBD-1 B18C1, Hondata S200 w/ P61 ECU, LS Tranny w/ Quaife LSD,ClutchMstr Stg 5,T/4 AR .60 w/ HKS Wastegate,RC 660 cc Injectors,Had Throttlebody,Skunk2 Intake Manifold,Eagle Sleeves,JE Pistons, Carrillo Rods,Stock Head & Internals,Thermal 3" Exhaust w/ no Cat,AEM Fuel Rail-Riser-UEGO-Cam Gears-Pullies-Fuel Filter,255 Fuel Pump,MSD 6A,GReddy Front Mount, 2-12's, 3 Amps,MB QuartComponents,Type-R Lip & 00 Head & Tailights,
2000 Integra Type R: Totaled
Old 06-15-2004, 01:58 PM
so what parts would I use for a ood custom kit that i would be able to keep a/c, and steel have a decent amount of power and be able to be at like 10 psi, with a b18c1 with upgraded internals?
Old 06-15-2004, 01:59 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
The FMU's that come with some kits are usually set up for 6-7psi of boost (the Greddy for sure) so if you're planning on boosting more than that you'll need to get a better engine management unit (ie Hondata.) But it really depends on what motor setup you have, whether you build the block to handle more boost or not, if you don't build the block then I'd say jsut use the FMU that comes with it until you do build (if you go the kit way). But also with the kit you might be stuck with how much the turbo is efficient, how many psi it will boost up to, and how much the wastegate will go to before blowing off. And the kit manifolds would only be compatible with a couple other turbos if you decide to upgrade the turbo down the road. With a custom kit you'll be able to get the right turbo for the power you want but with the kit you'd be limited to the turbo or turbo family the manifold you get comes with/works with. But you'll want to get it tuned no matter what you go with; more reliability and more power out of the kit.
Old 06-15-2004, 02:03 PM
Way to break it down CivicSpoon
Old 06-15-2004, 02:04 PM
CivicSpoon's Avatar
There is no Spoon
Oops...was writing while the other post were up I guess. There are mainfolds around that would let you keep the AC. Think that www.fullrace.com or whatever has some on their site that would let you keep it. But if you're wanting to go 10 psi I'd say go custom and get Hondata for an EMS (AEM EMS is way more expensive and I know a few people with it and they have nothing but problems.) And go with at least a T3/T4 turbo for good spool and boost, anything smaller wouldn't boost fully thru your rpms, i mean it'd max out too soon.
Old 06-15-2004, 04:52 PM
WASTEGATE regulates psi
uberdata or turboedit will work fine
Old 06-15-2004, 08:06 PM
anyone know of any kits that come with, t3/t4 or do u have to do that one your own? and is that about the highest youve ever seen a kits fmu get too was loike 6-7 psi, and coudlnt yu juss buy a hondata and use that with the or would it not work
Old 06-15-2004, 08:55 PM
turbonetics
revhard
drag
and many more kits use t3/t4 hybrid
fuel management has nothing to do with boost pressure. hondata is a good engine managment unit. without the boost option on hondata it's pretty much a basic ecu with tuning abilities. if you don't need a stand alone management unit then go uberdata or turboedit.
Old 06-15-2004, 09:02 PM
CivicSpoon's Avatar
There is no Spoon
DRAG turbo kits use T3/T4 turbos, don't know of any other from personal knowledge. I'm sure there are some kits that have the fmu for more than 6-7psi, but again I have no personal knowledge. On turbo-kits.com they have the FMAX listed as 8psi (i'm sure the kit itself will do more than that maybe that's the FMU max?) and the rev hard one says 15+ so maybe try to find more info on those. Oh yeah you could definently use hondata or what have you with a full kit.
CivicSpoon's Avatar
There is no Spoon
lol... yeah what Beyond said
Old 06-15-2004, 09:17 PM
Re: Re: Custom or Kit Turbos?
WASTEGATE:
A wastegate is used to control boost levels by allowing exhaust gasses to bypass the turbo, thereby decreasing the volume of exhaust available to spin the turbo's turbine which will limit the amount of boost created by the compressor. The wastegate has an internal spring and diaphragm which boost pushes on, these springs are rated for different psi levels.
