Old 06-14-2004, 11:12 PM
19k40rocky 19k40rocky is offline
89 tranny won't 2-3 shift
I put in a used transmission in my 89 GP with 2.8L engine. It road tested fine, then the other day I went to drive it and it shifted ok from 1-2 but will not shift 2-3. Fluid is good and at max level. TV cable is correctly adjusted and vaccuum lines are properly connected. Any ideas of what the problem most likely is and how do I fix it? What gets me is it operated great with no hint of problem and now this. Any help would be greatly appreciated!
Old 06-15-2004, 05:32 AM
kilroypr's Avatar
kilroypr kilroypr is offline
Send a message via MSN to kilroypr Send a message via Yahoo to kilroypr
Re: 89 tranny won't 2-3 shift
Well man do you get a DTC? sometimes if the shift solenoids are not working properly you will not get the sifhtting. So get your car scanned and check if there are any tranny related codes. Also is the speed sensor working properly?
My 93 lumina will run only in 1st if the speed sensor was dead
Old 06-15-2004, 11:18 PM
Unhappy
I swaped out the govenor and speed sensor and it shifts fine now. Got it back in the garage and found I have new problems that I need help with though. thanks for the help!
