Old 06-14-2004, 10:28 PM
hookworm hookworm is offline
Send a message via MSN to hookworm
timing - keeps changing
89 S10 Blazer 4.3 TBI
Replaced Engine
Most every sensor you can think of has been replaced
everytime you set engine timing, turn off and back on timing changes. have followed all procedures on setting timing every time you turn it off and then on its timing changes.
Any ideas
Old 06-14-2004, 11:28 PM
mjgjr72 mjgjr72 is offline
Re: timing - keeps changing
check crank pulley to see if seperating from hub
Click To See My Ride 2000 Chevy Silverado LT Z71 K1500 ecsb, 6" suspention lift, 4.56 gaers, 315/75r16 bfg mt, radix supercharger, gibson headers and cat back, trasgo shift kit, aluminum servos, nelson tune
Old 06-17-2004, 07:30 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
When you time it are you disconnecting the ECM from the distributor? If not you need to... Also remember you have knock sensors that help control timing.
Old 06-17-2004, 07:01 PM
ok i seem to have gotten the timing to work properly again, it is just running rough now and kind of low idle. any ideas
Old 06-17-2004, 07:12 PM
Rbraczyk Rbraczyk is offline
Send a message via AIM to Rbraczyk
I have that same problem with my K5. Could be TPS. Any check engine lights?
Old 06-17-2004, 09:56 PM
tacoma man.'s Avatar
tacoma man. tacoma man. is offline
Send a message via Yahoo to tacoma man.
your timing chain is worn out, got slack in it.
ive had this happen in the camaro.
