Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 05-14-2001, 09:36 PM
Shayyadin Shayyadin is offline
Question
First worry... I have a nice set of 17" rims coming in tomorrow, and I'm worried that my 1.5" lowering springs will combine with the bigger rims to give me camber problems in the back (where it's not adjustable) and eat (expensive) tires for breakfast.
Do I need a camber kit to go with that, or will the alignment be OK in the back?
2nd...
I never thought of this before but... a friend of mine (a physics nerd) pointed out to me that if you put bigger rims on a car, it would make sense that the spedometer would underestimate your velocity - not cool when you spot the cop and you're trying to go +under+ the limit.
I mean, traditionally the speedo taps into the driveshaft, so it doesn't give two shits what size your rims are. So if you go up to 18" rims, every 15" stock takes you 18", and you'll end up underestimating your velocity by 20%.
Is that an actual problem or am I dreaming shit up again?
Thanks for answering all my questions. I'm the "reluctant hot rodder" - I'll do it, but I'll be nervous about it for the first thousand miles!
Shayyadin
Old 05-14-2001, 09:58 PM
MaximumBrian's Avatar
MaximumBrian MaximumBrian is offline
Send a message via ICQ to MaximumBrian Send a message via AIM to MaximumBrian
Since your car isn't rear wheel drive and it certainly doesn't steer with the rear wheels, than rear tires won't really wear very quickly. I'm dumped over 3" 's with 16's and I wear almost evenly.
July 2001 Maxima of the Month
1997 Nissan Maxima SE 5Spd - Sage Mist Green - 5Spd: Leather, Dual Power Seats, Climate Control, Bose, Moonroof
Mods: Stillen 5 Piece Aero Kit / 5Zigen GT8 17" Rims / Nitto NT555 ZR-W 235/45/17 Tires / Suspension Techniques Modified Springs / Tokico Blues / Stillen Front Strut Tower Bar / Stillen Rear Sway Bar / Greddy Catback Exhaust / Cattman Y-Pipe / Random Tech 2.5" Straight Through Cat Converter / PR Cold Air Intake Adapter / Stillen ShortRam Intake with Velocity Stack / GForce 96 ECU (Testing for Maximadriver.com/Cheston) / Stillen Carbon Fiber Dash / Clear'd Amber Out of Taillights / Courtesy Front Clear Corners / SS Brake Lines / Porterfield Pads / Cut Shift Handle / Autolite Titanium Spark Plugs / B&M Carbon Fiber Shift Knob / Razo Carbon Fiber Pedals / JL 12W3 12" / Kenwood 650 Watt Amp / Redline MTF / Mobil 1 5w30 every 2500 miles / Wax every 3 months
180 FWHP - 186 TQ [Before Cat & ECU] (Outside 90F, one small worthless fan) / Estimate Power (w/ Cat & ECU) 190 FWHP - 200 TQ / 14.7 @ 94 [Before Cat & ECU] (Pomona 01/2001 - Cool/Overcast day)
http://www.brianv.net
Who wants some???
Support my business so I can mod my Maxima - http://www.vsdev.com
Old 05-15-2001, 07:23 PM
Lordrandall's Avatar
Lordrandall Lordrandall is offline
Send a message via ICQ to Lordrandall Send a message via AIM to Lordrandall Send a message via Yahoo to Lordrandall
Here are a few wheel/tire size calculators you can use to make sure your speedo and odo stay correct.
http://members.aol.com/mx6perform/tirecal.htm
http://www.cs.fredonia.edu/~stei0302.../tirecalc.html
http://www.powerdog.com/tiresize.cgi
Also try http://www.tirerack.com they have a link that will give you good tire sizes to stay close to stock dimensions.
Good luck!
Someone give me a cookie
gas mileage decreased with new tires?? Dolphingrrl23 General Discussion 5 08-21-2009 04:01 AM
Issues with squeaking tires. Zandra Cavalier Problem Diagnosis 1 07-29-2009 05:06 PM
How do I calculate speed with Bigger tires? lightningflash12 Cherokee 2 10-05-2005 04:26 PM
For Everyone with Bigger Tires JasIzBac General 1 03-10-2002 10:47 PM
For Everyone with Bigger Tires JasIzBac Cosmetics 0 03-10-2002 01:39 AM
