Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 06-14-2004, 08:02 PM
danforth45's Avatar
danforth45 danforth45 is offline
low oil pressure?
I have a 97 3.2 rodeo. I have noticed that my oil pressure seem a little low, I is usually a little bit 85 when I am cruising and between 85 and 0 when I am idleing. Does this seem low to anyone? or is this normal? The owners manual says the pressure can get to 140 during cold accelleration, mine never gets over 85. any ideas would be appreciated.
Old 06-15-2004, 11:59 AM
Swiss1 Swiss1 is offline
Re: low oil pressure?
I have a 96 Trooper with the 3.2 V6 in it and the same deal. I also heard about that from other Trooper owner. Try to use thicker oil in the summer and see if it changes.
Andy
Old 06-15-2004, 09:39 PM
danforth45's Avatar
that makes sense, right now i'm useing 5w-30 mobile one and I live in south florida!!! i'll switch to 10w-30 next oil change. did you have low oil pressure? if so did thicker oil help you? andy
97 Rodeo 4x4 3.2 SOHC V6
191k and running strong
31x10.50 Maxxis Buckshot
Manik grille guard
100w hella drining lights
Old 06-15-2004, 10:44 PM
Re: Re: low oil pressure?
When I bougth the Trooper (with 83'000 miles on it) i emediately put in 10W30 and it doesn't drop down to 0 when running. By starting the engine when cold it comes up to about half way (I think that is 85 psi?) for a second and slowly decreases with temp to about 1/4 indication.
I don't know how accurate the indicators are, but as long as you have enough oil in the engine and it gives you some indication, compared to when engine is not running, don't worry.
Andy
