Old 06-14-2004, 04:52 PM
GCguy2169 GCguy2169 is offline
Send a message via AIM to GCguy2169
Amp for 4 12's
What would be the best amp to buy for under $300 bucks, to push 4 400RMS 12's?
Coming soon..RE XXX 18'', Hifonics Brutus Amp..Any comments on these products please respond in any thread of mine.
Old 06-14-2004, 05:20 PM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
Re: Amp for 4 12's
get 2... you will want it, but under 300... try the nine.1 it is about 278 shipped
www.cloudcity.deviantart.com
Old 06-14-2004, 05:57 PM
loismustdie loismustdie is offline
how about a jbl 1200.1, that will give 300 watts to each sub if its wired correctly, and will get hella loud
the aquabats are seriously the best band in the world
Old 06-14-2004, 07:00 PM
Haibane's Avatar
Re: Amp for 4 12's
the nine one aught to give a little more than 300 per sub... also, what is the impendence on the subwoofers?
Old 06-14-2004, 09:08 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: Amp for 4 12's
PG 1200.1 would work too
Nine.1 might not, depends on the impedence of the subs
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 06-15-2004, 09:45 PM
The subs are DUAL 4-ohm. 400 R.M.S. a piece. Built my box today (June 15) about 8.3 cubes in all, 4 4 inch square ports tuned to 35 Hz. Should Bang?? Fixin' to get me an amp, lemme know...
Remember DUAL 4-ohm.
btw- I was thinkin since I'm on a very strict and tight budget, maybe some profiles. Some of them put out about 300 RMS x 2, at 2 ohms. If i got 2 of them, it would cost me about....$160 shipped? Good deal, good quality?
Old 06-15-2004, 09:47 PM
sr20de4evr's Avatar
Re: Amp for 4 12's
hmm, so you have 8 4ohm coils....
lets see, you can get .5ohm, 2ohm, 8ohm, 32ohm, and probably some other insignificant ones in between, the point being you cannot get 1ohm, so the nine.1 wouldn't work. JBL 1200.1 or PG 1200.1 get my vote.
'01 Black Sentra SE
'05 Silver WRX STi
Old 06-15-2004, 10:14 PM
What sites, and where can I find these amps at? What do they run? What do u think about the box?
Old 06-15-2004, 10:16 PM
sr20de4evr's Avatar
Re: Amp for 4 12's
Not a clue on the box, the box design depends completely on the subs that are going to be used in it.
Anyway, for the amps try www.woofersetc.com and ebay
Profile amps are pretty solid, but honestly they're still very low budget amps. I would go with JBL or PG instead if you can afford it, if you can't then the Profile should be fine, stick to the California line though.
'01 Black Sentra SE
'05 Silver WRX STi
Old 06-16-2004, 11:45 PM
bumpinstang77's Avatar
bumpinstang77 bumpinstang77 is offline
Send a message via AIM to bumpinstang77
Re: Amp for 4 12's
go with two seperate amps that will put out around 5-600 rms at 1 ohm or 4 ohms.....I wouldn't be comfortable putting those x-sites at full power. Perhaps two bx500d's or one bx1500d @ 2 ohm.
