Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 06-14-2004, 02:52 PM
salchichon20 salchichon20 is offline
gsr ecu
i have a 2000 jdm b16a with a 95 gsr tranny set up... i just recently put a 96 gsr ecu and i have 2 questions... my idle is supposed to be at 900 rpms and at idle it keeps reving by itself but not much just jumps back and forth from 900 to about 1200 wanted to know whats causing the problem...second question whats the redline on a stock 96 gsr ecu? thanks
Old 06-14-2004, 02:58 PM
Beyond Imagination's Avatar
Beyond Imagination Beyond Imagination is offline
Re: gsr ecu
what is your air/fuel at?
88 Honda CRX Si - B16
90 Honda CRX Si - B20VTEC
Old 06-14-2004, 03:01 PM
i really dont know what my air/fuel is right now u think thats the problem?
Old 06-14-2004, 03:12 PM
B1SiR6A's Avatar
B1SiR6A B1SiR6A is offline
Re: gsr ecu
...where did you get the motor from?...as far as i know there was no 2000 jdm b16a they were only in integra xsi's and civics in the early 90's the only 2000 b16a was usdm...check you tps for the idle surge (or search..."idle surge") and the redline for a stock gsr is 8100 I think...
"Check that young man for nitrous"
12.428 @ 92.5 Mph
Before, Now
12.000 @ 94.1 Mph
On 1000ft Track
Currently 4th in BHRA All Motor Class...Soon to be 2nd (I hope)
...Theres gonna be alotta slow singin, an flower bringin if I hear my car alarm start ringin ...
Re: gsr ecu
i'm just wondering why you're using a b18 ecu with a b16 engine ... wondering how your air/fuel is seeing if you're running too rich.
Old 06-14-2004, 03:15 PM
B1SiR6A's Avatar
Re: gsr ecu
yeah why is that...it is always better to use the ecu of the head of the engine in this case b16a head b16a ecu I dont think the gsr ecu will benefit you in the area of performance as much as the b16a ecu would be able to
12.428 @ 92.5 Mph
Before, Now
12.000 @ 94.1 Mph
On 1000ft Track
Old 06-14-2004, 03:26 PM
i had 5 people tell me to get a gsr ecu with the motor instead of the b16a maybe they are wrong but when i put the ecu it really made a difference i still have to try the b16a ecu ...
Old 06-14-2004, 07:00 PM
colin161822 colin161822 is offline
Send a message via AIM to colin161822
things that would cause the idle to go up and down could be a vacuum leak or a bad idle air control valve. to check for a vacuum leak, get some brake spray and spray it in the area of the manifold. quick short bursts. if the idle drops quick, like it is starving for air, which it is doing then you have a leak. other then that it is possibly the iac. it could be clogged or bad. its job is to warm up the car. so it holds the idle high for a little until its sensor tells it that the coolant is up to a certain temp and then it drops the idle. in your case it goes between both. it isnt certain what to do. that is why it could need a cleaning or be replaced. since the motor is new it could be just dirty. what i would do is pull the idle screw out and clean that and service the throttle body as well. and then set the idle back to 750 with no lights or any other idle up components on.
also using a gsr ecu is most likely not your problem. unless it is bad. you can use that ecu or some other choices. what year is your car?
and B1SiR6A they made b16's all the way up until 2000 in japan. they came in ek4's.
VISIT: WWW.161822ONLINE.COM
Old 06-15-2004, 09:47 AM
i have a 95 honda civic ex coupe ... i bought the block and the head all the papers say the block and the head are 2000 jdm ... and about the ecu every mechanic told me to get a 96 gsr computer and change the distributor ,spark plug wires to 96 gsr and get a msd ignition set up...
Old 06-15-2004, 12:09 PM
dont change the ignition system. the stock one works just fine. and no need to change the distributor.
are you haveing any other runablity problems?
another question, where did the trans come from? you didnt buy a change over?
Old 06-15-2004, 12:37 PM
drag1320neon's Avatar
drag1320neon drag1320neon is offline
Send a message via Yahoo to drag1320neon
Re: gsr ecu
sounds like a vacum leak or a fucked up iac sensor
you aint gotta like me, you just mad cause i tell it how it is, and you tell it how it might be
CHECK OUT MY CARS HERE!
drag1320neon and 209neon's babys < 209 neon finished!>
Old 06-15-2004, 01:28 PM
i have a 96 gsr tranny on the jdm b16a and yeah i think its one of the sensors
Old 06-15-2004, 01:31 PM
my bad 95 gsr tranny
Old 06-15-2004, 07:06 PM
ok another thing, are you sure it is a 96 gsr ecu. a 96 will not plug directly in. you would need to run a harness converter.
95 is still obd-1 and 96+ = obd-2.
