Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 06-14-2004, 01:52 PM
TundraVt TundraVt is offline
Unhappy spark plug change 1995 exp. V6
Drivers side looks easy. Passenger side looks difficult. Is it possible to change from above? If so what tools? Also what brand of plus do you suggest? Thanks
Old 06-14-2004, 09:58 PM
mabulok mabulok is offline
Re: spark plug change 1995 exp. V6
I use a combination of extensions, coupled with one of those universal joint-like adapters that get into areas where you need an angle on your extension. It's tricky, but not too bad once you get the hang of it. If I remember right, the rear passenger plug was accessible a little easier from under the truck. Just be careful not to break the ceramic. As for brand, I use oem. I've read where some have had problems with heat using the performance brands.
Old 04-15-2005, 06:46 PM
davidmmm davidmmm is offline
they are all very simple to get to
