Go Back   Automotive Forums Car Chat > Honda > Integra
Old 06-14-2004, 04:21 AM
exitpexit exitpexit is offline
Send a message via AIM to exitpexit
tranny grinding, clutch problem ?
i recently got a 90 teg, and after the car warms up or i rev hard in 1st gear it'll grind into 2nd gear, sometimes happens from 3rd to 4th as well. i thought it was my tranny. but then i asked a few people that have more knowledge than i and they all told me it's the clutch, and that it needs to be adjusted because it's not disengaging properly. so i've gone around searching for info but i only find the same info telling me to 'adjust the clutch', finally my question is, how exactly do i 'adjust the clutch' ? should i change my clutch ? or can i fix the current one ?
Old 06-14-2004, 07:32 AM
udelblue udelblue is offline
Re: tranny grinding, clutch problem ?
you can only adjust you clutch if it is a cable clutch and not hydrolic, i am not sure about your make, does it take dot 3 or 4 fluid than it is a hydrolic clutch
Old 06-14-2004, 07:33 AM
sounds to me likek you need to replace the clutch, and throwout bearing, also resurface the flywheel.
Old 06-14-2004, 08:26 AM
Morissette23 Morissette23 is offline
Send a message via AIM to Morissette23 Send a message via Yahoo to Morissette23
Re: Re: tranny grinding, clutch problem ?
Try bleeding the clutch line. If its hydrolic you CAN adjust the height of it, under the pedal theres a nut, turn the nut and move the clutch pedal, down or up then tighten the nut.
Old 06-14-2004, 09:15 AM
knorwj's Avatar
knorwj knorwj is offline
Send a message via AIM to knorwj
2nd gens have a cable clutch NOT hydraulic. first of all check the pedal height it should be about 7 inches off the floor. no push the pedal in with you hand it should move about 3/4 of an inch before it starts disengageing. now move around and pop the hood. look for an arm coing out of your tranny with a cable attached to it. this arm should only have like an 1/8 of an inch of freeplay in it.
ok now if any of those adjustments are off there is a plastic nut on the cable I mentioned earlier right above where it hooks into that arm. turn it until all the numbers match up to the ones I said.
If the clutch won't adjust or if you can't get the numbers to match up then you may need a new clutch. chances are you do anyway... a worn slipping clutch can be adjusted, sounds to me your release forks or throw out bearing is bad in which case adjusting will do nothing.
summary: I think these numbers are correct (at least they are for Mine) I highly recomend buying a manual that will tell you the exact numbers for your specific year as the wrong adjustment will screw stuff up.
Pedal Height~ 7"
Pedal Freeplay~ 3/4"
Cable freeplay~ 1/8"
edit: actually I have a manual around here somewhere give me the day and I'll post up the exact numbers tonight.
Old:
1993 Acura integra gs-r
New:
1998 chevy BlaZeR2~ AKA "Jeep recovery device"
Newer:
2007 Honda CB900F "919"
Old 06-14-2004, 07:09 PM
knorwj's Avatar
ok here are the right numbers.
integra 90-93
pedal height= 7"
pedal freeplay= 19/32" - 25/32"
release arm freeplay= 5/32" - 13/64"
Old:
New:
Newer:
Old 06-15-2004, 02:13 AM
wow .. thanx for all the info. i just got in from work, i'll try these adjustments first thing in the morning, and once again, thanx alot .
