Old 06-14-2004, 02:36 AM
jestersrain's Avatar
jestersrain jestersrain is offline
Send a message via AIM to jestersrain
turbo vs supercharger
i was wondering what would be better for my 1998 ss, a turbo or a supercharger? what arwe the pros and cons of one vs the other? car is being built up to street drag. die rice burner!
Old 06-14-2004, 03:07 PM
DiabloGT's Avatar
DiabloGT DiabloGT is offline
Banned
Re: turbo vs supercharger
turbo, they are both usually around same price and almost about same hp, except one nice thing about a turbo is that when your engine is about to blow up it uses less horsepower too cool it down, and saves the engine, the supercharger doesnt, and the turbo has usually 6 levels of boost to put how much more hp you want to use... anyways they both rock in my opinion though turbo>supercharger...
Old 06-14-2004, 07:06 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
um..... never heard of a multi stage turbo, and if they are out there, i wouldnt call them normal. anyway, in my experience, both are perfectly reliable, and safe so long as you use them properly. as far as which is the better power adder, in the past, i would say supercharger, however i am a recent turbo convert, and would have to say now that for a total average power curve, the turbo is best, but for max peak power, the centerfugial supercharger is king. modern turbos also spool up faster, almost negating the instant power responce of a belt driven supercharger, but you cant even compair the ease of installation of a supercharger vs the tangled mess of custom piping required to install a turbo.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 06-14-2004, 07:20 PM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
well if you got money... twin turbo it!
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 06-14-2004, 09:09 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
naw supercharge it. you guys ever seen the video of the supercharged lingenvette? check it out on their site, the vid is nasty, and damn does that sob scream. ill tell you what, twin turbos arent gonna yell that loud...
Old 06-14-2004, 10:21 PM
Dober89 Dober89 is offline
I have a video of a twin turbo grand national and the noise it makes is retardedly loud, it even burns rubber on the chassis dyno.
Old 06-14-2004, 10:36 PM
DaMoNe6969's Avatar
DaMoNe6969 DaMoNe6969 is offline
If he's building a car to street drag, I think power is gonna be more important over the noise it makes..
Well, im not sure what Diablo was talking about with the 6 stage turbo, You can get a boost controller that will let you adjust how much boost you want to run within the turbo and engine limits.. And im not sure what he meant by taking less horsepower to cool down?? But In my opinion turbochargers are better.. They make less power than superchargers, but a turbo works off waste exhaust gas, so it robs your engine of about 3 horsepower from backpressure.. A supercharger makes more power but runs off of the crank, Ive heard of some superchargers robbing up to 50 horsepower... In terms of dependability, ide say they're about the same.. I think your car would be more streetable with a turbocharger over a supercharger.. The biggest con to turbocharging is, as Iroc mentioned, It is one hell of a job to custom in a turbocharger.. Superchargers can be done in an afternoon
1991 Camaro Z28
Old 06-14-2004, 11:54 PM
ridge_runner ridge_runner is offline
Send a message via AIM to ridge_runner Send a message via MSN to ridge_runner
Re: Re: turbo vs supercharger
are you talkin about the banks six-gun system for turbodiesel trucks???
Old 06-15-2004, 07:32 AM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
Turbo boost is controlled by how much exhaust pressure and exhause heat is inside the turbine housing. If you want more boost put more pressure and heat in the turbine, if you want less let some out(IE a wasegate) A turbocharger will make more power than a supercharger bar none. They are not as parasidic. Take a top fuel car for example, to make max boost on a top fueler it takes over 1000 HP to spin a top fuel supercharger ( I don't know what size they use.) If you had a Turbo setup on one it would only take about 15 HP to make the same kind of boost. That is why they do not allow turbochargers in top fuel. it would throw alot more power at an already uncontrolable car. That and there is no pratical way to control that ammount of exhaust
I have driven supercharged v-8's and turbocharged v-8's both running 17 PSI of boost and both were similar engines (Supercharged montie carlo with a built 350, Turbocharged Mustang 351W) The turbo engine was sooo much more powerful. Well worth the time and effort IMO
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 06-15-2004, 08:00 PM
89IROC&RS's Avatar
well hypsi, not to contradict, but it also depends on what kind of supercharger you are talking about. roots style superchargers for the street are the bottom of the mole hill, making less peak and less average power. turbos are next, making much better average power and better peak power. however, a centerfugal supercharger will sacrifice a bit of lower end power, but will make more peak power than the turbo. ive seen more than one back to back to back test to proove this, although it does depend wholy on your setup and options to the power adder.
but i still say the turbo is the best all around choice, if you have the money and patience for the install, if youre looking for great power, thats easy to install, the centerfugal supercharger cant be beat.
Old 06-15-2004, 08:04 PM
whats the normal price including installation(or ne other parts you need if theyre possibly DIY jobs)?
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
Old 06-16-2004, 02:07 AM
DaMoNe6969's Avatar
for a turbocharger or supercharger?
1991 Camaro Z28
Old 06-16-2004, 02:14 AM
Both
Old 06-16-2004, 07:33 AM
Hypsi87's Avatar
http://www.precisionte.com/products/...=Turbochargers
That should give you an idea on turbocharger costs
Back in action!!!!
1999 Ford F-250
ASE Certified in...
Mobile AC
On highway trucks.
Member of
