Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 06-14-2004, 02:00 AM
Auto_newb Auto_newb is offline
Question V-Tec and DOHC
I got 2 questions:
1) Does F/I go with V-tec well, I heard if I were to turbo my vtec engine, it would screw the v-tec over
2) A friend of mine wants to know if she can make her car a DOHC by swapping her current stock civic head for a b16 head.
Old 06-14-2004, 03:07 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
1. idk who you heard that rumor from but FI goes good with vtec and those who say it doesnt is stupid. you might have to adjust vtec engagment alittle but its nothing.
2. no you cant put a b16 head on her stock d series block
Team Lonely Drivers
Old 06-14-2004, 10:18 AM
Re: V-Tec and DOHC
1. Doesn't the valve lift let out all the blowing air due to valve overlap?
Old 06-14-2004, 11:29 AM
Beyond Imagination's Avatar
Beyond Imagination Beyond Imagination is offline
Re: V-Tec and DOHC
you can use short duration high lift cams if you really wanted.
88 Honda CRX Si - B16
90 Honda CRX Si - B20VTEC
Old 06-14-2004, 01:17 PM
Re: V-Tec and DOHC
Umm.. That wouldn't work to well would it? Wouldn't you lose power because since the valve closes early, the cylinder doesn't get filled completely?
Old 06-14-2004, 02:29 PM
Re: V-Tec and DOHC
but you're talking about FORCED induction where compressed air is being used.
Old 06-14-2004, 08:54 PM
Re: V-Tec and DOHC
That's true, but would it affect it at low RPMs?
Old 06-14-2004, 09:47 PM
crzyCollegeKid crzyCollegeKid is offline
Re: V-Tec and DOHC
well....unless your going with nitrous or a supercharger, your gonna have less power at lower rpms from a turbo setup considering it has to spool. and its vtec, not v-tec.
i saw some dumb mofo with a "S-ER" sticker on his sentra, lets not make such laughable mistakes
(i also saw another dumb mofo with a "DOHC VTEC" emblem on his celica)
Not-named-yet:
2011 Hyundai Sonata SE w/Sunroof and Nav in Iridescent Silver Blue Pearl
Claudia (traded-in):
2003 Mitsubishi Eclipse GTS: Pioneer Speakers All Around, Kenwood MP3 Deck, Clarion Equalizer, Boss 4ch. 800W amp, 2 Dual 12" subs with Dual 500W amp, XM Roady2
R.I.P. Jessica
1997 Honda Prelude: AEM CAI - Exedy Full Face Organic Clutch - XACT Streetlite 12.5lb flywheel - DC Sports Short Throw Adapter
Old 06-15-2004, 02:32 AM
Re: V-Tec and DOHC
So it's kinda "wasting" the !!"VTEC"!! right?
Old 06-15-2004, 03:57 AM
idk where everybody gets this idea about valve overlap. if hte valves overlap as much as you think then youd lose power. i havent seen anybody lose power from putting cams on there car. it does overlap alittle but its very small. this is a big myth being spread around by people who think they know when they dont really know.
the whole idea with FI is to get as much of the compressed air into the cylinders as you can, ie with cams, intake mani, tb, etc. so why would it be bad to put cams in so you can get more of the compressed air into the cylinders.
Team Lonely Drivers
Old 06-15-2004, 11:04 AM
Re: V-Tec and DOHC
So are you saying VTEC will NOT have any conflicts with any form of F/I?
Old 06-15-2004, 11:38 AM
Privatebigandrew's Avatar
Privatebigandrew Privatebigandrew is offline
Send a message via AIM to Privatebigandrew Send a message via Yahoo to Privatebigandrew
Re: V-Tec and DOHC
OK...let me put an end to this. Forced induction does not like valve overlap. Look at it this way. Compressed air is being forced into the cylinder with the intake valve open. All of a sudden the exaust valve opens while the intake vale is open too. A lot of that compressed air is going to go aout the exhaust valves due to the low pressure on the exhust side from the turbo sucking out the air. Also that air that is in the cylinder is going to want to go out the exhaust chamber even more due to the pressure from boost on the intake side. Now, contrary, a little bit of overlap (such as with VTEC) isn't going to hurt anything. it actually helps spool up the turbo faster by forcing the air out into the exhaust manifold, therby spooling up the turbo. But if you have too much overlap, too much air goes out the exhaust and boost is wasted. The ideal turbo cams would have high lift and short duration.
94' Del Sol VTEC (B16A3) SOLD.
Accel plug wires, NGK iridium IX plugs, AEM short ram intake, DC sports ceramic coated header (4-2-1), Airmass high flow cat ,Custom Magnaflow exhaust, Bosal Brospeed tips, Neuspeed short throw shifter, Tokico clutch master cylinder, Tokico clutch slave cylinder, Prothane complete kit bushings, Brembo front rotors, NR EL-Glo instrument gauges, CTR LSD trans with ITR final drive, Exedy chromoly flywheel, ACT HDSS clutch kit, Raxle axles.
Old 06-15-2004, 02:13 PM
YellowITR479 YellowITR479 is offline
Re: V-Tec and DOHC
My car loves the forced induction w/ vtec....wouldnt have it any other way
1996 GSR w/ 1995 OBD-1 B18C1, Hondata S200 w/ P61 ECU, LS Tranny w/ Quaife LSD,ClutchMstr Stg 5,T/4 AR .60 w/ HKS Wastegate,RC 660 cc Injectors,Had Throttlebody,Skunk2 Intake Manifold,Eagle Sleeves,JE Pistons, Carrillo Rods,Stock Head & Internals,Thermal 3" Exhaust w/ no Cat,AEM Fuel Rail-Riser-UEGO-Cam Gears-Pullies-Fuel Filter,255 Fuel Pump,MSD 6A,GReddy Front Mount, 2-12's, 3 Amps,MB QuartComponents,Type-R Lip & 00 Head & Tailights,
2000 Integra Type R: Totaled
Old 06-16-2004, 07:30 PM
Re: V-Tec and DOHC
So if I turbo'd or SC'd a civic, I would have to change cams to just so I don't get this problem or what?
Old 06-17-2004, 01:03 AM
95TegSE's Avatar
95TegSE 95TegSE is offline
Re: Re: V-Tec and DOHC
No, the overlap of the stock cams isn't long enough to cause major problems.
From the foothills to the bay, it shall ring, as we sing,
It shall ring and float away; Hail, Stanford hail! Hail, Stanford hail!
