Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 06-14-2004, 12:40 AM
mattilude mattilude is offline
Send a message via AIM to mattilude Send a message via MSN to mattilude
the Lude is missing around 2k rpms
alright guys, my first problem w/ my 93' SI lude. It misses around 2k rpms like when i'm accellerating.. it has new plugs and wires.. and it seemed to do it after i washed my engine w/ degreaser and a hose.. ic overed up my distributor, and air filter.. now what is going on?
Old 06-14-2004, 07:40 AM
DJ Brady DJ Brady is offline
Send a message via AIM to DJ Brady Send a message via Yahoo to DJ Brady
Re: the Lude is missing around 2k rpms
sounds like you got water in the plug wire holes (in the top of your valve cover)
I accidentally did the same thing.. the water grounds the spark against the valve cover. Pull your plug wires off, look in each hole, there's probably standing water in there. I had to take a paper towel and poke it in the hole to soak up the water out of a couple of my plug holes.
I don't mean inside the cylinder, so don't go pulling plugs out, but the recesses where the plug wires go down onto the plugs.
