Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 06-14-2004, 12:09 AM
SenseiAccord SenseiAccord is offline
Difference b/w Gas Octane
So what is the difference b/w the regular 87, plus 89 and premium 92/93 octane gases other than octane level and price?
What i think is that premium is a waste of money unless u really need it for high compression or for racing purposes. I say racing b/c during racing the car runs really hot due to high reving and using a higher octane will just let ur car run w/ less chance of knocking. basically what im saying is it will allow u to race safer. I dont think it will give u better gas mileage or even clean ur engine or make it run cleaner. what i think is if u are running less than 10:1 comp then 87 is just fine for you and using anything higher is just wasting ur money. Then again racing gas, 100 octane and up, has lead in it which is good for ur engine but bad for the cat and the environment. i hear even 100 unleaded has some lead in it but not much which in return is still good. ppl claim they get more hp by using high octane but i dont think that is true... 1-2 hp is pretty much impossible to be noticable by human senses and just a psychological thing.
Post ur guys opinions and theories... proof will actually be best here.
Old 06-14-2004, 12:27 AM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
Re: Difference b/w Gas Octane
You pretty much nailed it..
Old 06-14-2004, 12:28 AM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
I personally use the Premium gas whenever I have the $ on me to do it, and I'm just running my stock CX engine. But I definently can tell the difference in when I run a higher grade gas than the 87. My car runs a lot smoother, so much that I stall my car all the time cause I can't feel the engine shake before it stalls like I can with the cheap stuff. Of course I'm not running a high hp setup so I definently don't notice any added hp from it or even better gas mileage. My buddy who's a mechanic tells me that it just burns better than lower grade gas.
Old 06-15-2004, 02:01 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
there is actually an improvement in HP using a higher octane, when the vehicle requires it. Sport Compact Car did a test last year using a modded 350z and then first using 91octane, then switching to race fuel, like 133octane, netted them almost 10-15 more hp. but like you said, it is not needed if the car cant benefit from it.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 06-15-2004, 02:08 PM
YellowITR479 YellowITR479 is offline
Yea...ummm.... you did pretty much nail it
1996 GSR w/ 1995 OBD-1 B18C1, Hondata S200 w/ P61 ECU, LS Tranny w/ Quaife LSD,ClutchMstr Stg 5,T/4 AR .60 w/ HKS Wastegate,RC 660 cc Injectors,Had Throttlebody,Skunk2 Intake Manifold,Eagle Sleeves,JE Pistons, Carrillo Rods,Stock Head & Internals,Thermal 3" Exhaust w/ no Cat,AEM Fuel Rail-Riser-UEGO-Cam Gears-Pullies-Fuel Filter,255 Fuel Pump,MSD 6A,GReddy Front Mount, 2-12's, 3 Amps,MB QuartComponents,Type-R Lip & 00 Head & Tailights,
2000 Integra Type R: Totaled
Old 06-15-2004, 05:30 PM
Privatebigandrew's Avatar
Privatebigandrew Privatebigandrew is offline
Send a message via AIM to Privatebigandrew Send a message via Yahoo to Privatebigandrew
Higher octane doesn't "give" you HP, it frees up HP. Higher octane is actually bad for your car unless it calls for it like you said. A higher octane fuel burns colder than a lower octane fuel and takes a lot more heat to ignite it. That is why higher compression engines need it, so they don't preignite. Since the higher octane fuel burns colder, putting it in an engine that calls for lower octane (burns hotter) will cause excess carbon deposits. Now, an old engine has carbon deposits on the cylinders and what not, so its gonna have slightly higher compression than when it was brand new, but not enough to put in a higher grade fuel.
94' Del Sol VTEC (B16A3) SOLD.
Accel plug wires, NGK iridium IX plugs, AEM short ram intake, DC sports ceramic coated header (4-2-1), Airmass high flow cat ,Custom Magnaflow exhaust, Bosal Brospeed tips, Neuspeed short throw shifter, Tokico clutch master cylinder, Tokico clutch slave cylinder, Prothane complete kit bushings, Brembo front rotors, NR EL-Glo instrument gauges, CTR LSD trans with ITR final drive, Exedy chromoly flywheel, ACT HDSS clutch kit, Raxle axles.
Old 06-17-2004, 02:07 PM
TheAznPersuazun TheAznPersuazun is offline
higher octane isn't BAD for your car persay...it all depends on the quality of ur plugs, wires, & valves cuz if there's too much octane your the plug will spark b4 they are up all the way so you'll start to hear a "pinging" sound....but don't get higher than 93 octane on a DD. I personally get super all the time just cuz it's cleaner and will help keep your internals running longer. and NO higher octane doesn't add HP
Old 06-17-2004, 08:43 PM
don't reply if you don't know what you are talking about. If there where a high amount of octane it would not spark before TDC....the spark is going to occur at the same time regardless of the octane. You are thinking of preignition. It would have a tendency to preignite later not sooner. Higher octane takes more heat before it self ignites, so therfore, the cylinder pressure would have to be greater for more heat. (pressure=heat) cylinder pressure is at its most when the piston is at TDC, unless you have massive overlap. It is not cleaner in the long run. Read my first post. Carbon deposits are not good for your engine my friend.
Old 06-17-2004, 09:02 PM
let me clear up the whole idea of high octane gas not being cleaner as i can see it is unclear. Look at it this way. Yes higher octane gas burns cleaner. But, higher octane gas burns colder also. If high octane gas were put in an engine with low compression, there would not be enough heat to burn all of the carbon away, and over time this carbon will build up. In a high compression engine, the cylinders get hot enough to overcome the cooler burning high octane gas. And to think, i paid for this education, and here i am giving it away for free. where's my donations...J/K
Old 06-18-2004, 01:49 AM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
yeah my bud that's got a 98 lude says it's very noticeable when he puts in the 91 octane compared to the 89... then again his car calls for premium anyway, he says he notices highly improved has mileage as well... did something like 350 k on half a tank o gas on the highway..
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
