Go Back   Automotive Forums Car Chat > Plymouth > Horizon
Old 06-13-2004, 10:13 PM
Arkie Hobbs Arkie Hobbs is offline
1987 plymouth horizon timing problem
Help! I just replaced the distributor with a remanufactured one and just rebuilt the carburetor. I took the vacuum line loose from the spark control computer as given in the instructions. The timing is unsteady and bounces back and forth from 10 to thirteen degrees. What is causing the bouncing back and forth? What should I try?
Also, it idles rough and the compression in Cylinder one is 150, cylinder two is 148, cylinder three is 143, and cylinder four is 134. Is this a problem?
BTW, this is a 2.2 with automatic transmission, carburetored fuel delivery, and has just over 47,000 miles on it.
If anyone would like to E-mail me, my address is [email protected]
Thanks in advance for the help.
Arkie
P.S. We just did a vacuum test and everything checked out great.
Again, thanks in advance.
Old 06-23-2004, 01:20 PM
slantsixness's Avatar
slantsixness slantsixness is offline
Re: 1987 plymouth horizon timing problem
Loose timing belt tensioner, or bad timing belt
Could also be a broken or cracked distributor gear or gear drive.
If I knew what I did to break it, I would've known not to do what I did.
www.classicwinnebago.com
Old 06-23-2004, 04:40 PM
Re: Re: 1987 plymouth horizon timing problem
Thank you!
For some reason it is already doing better after I set the idle up to the 900 RPM the book advises.
Blessings to you.
Arkie
Old 08-11-2004, 03:15 PM
TrailLeadr's Avatar
TrailLeadr TrailLeadr is offline
Wow, only 47k miles on it. I wouldn't worry about your compression, although for such low miles, you shouldn't have such a variance. anything over 120 for that engine will get you by quite well.
93 Suburban 2500
203,000 miles on engine still running like a champ!
Tranny rebuilt at 197,000
My Daughter calls it the bus, and sits in the
third row seat praying for potholes and speedbumps!
Just Horsin' Around Equine Services
http://www.JHA-Trans.com
