Go Back   Automotive Forums Car Chat > Honda > Integra
Old 06-13-2004, 09:15 PM
charlieteg charlieteg is offline
Send a message via AIM to charlieteg
stroker kit
i was just wondering what a stroker kit is, i have no idea, and any little info would help
charlie
Old 06-13-2004, 09:45 PM
sameintheend01's Avatar
sameintheend01 sameintheend01 is offline
Send a message via AIM to sameintheend01
Re: stroker kit
makes the stroke of the piston longer...so it increases displacement and decreases the max engine speed.
Clear Corners
Front and Rear Strut Bars
Cold Air Intake with K&N filter
Iridium Spark Plugs
High Performance Plug Wires
High Flow Cat (unistalled)
Cool high/low beam lights
All around slotted and AEM pads
Old 06-13-2004, 09:57 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: stroker kit
A stroker kit decreases the max engine speed?
Old 06-13-2004, 11:08 PM
Re: stroker kit
the absolute max the stock original can handle....think about...let's say the piston can go up and down a maximum of 8000 times a min. a distance of 3 inches. if u increase the distance to 4 inches, it isn't going to be able to go longer distance in the same amt of time.
Clear Corners
Iridium Spark Plugs
Old 06-13-2004, 11:40 PM
Re: stroker kit
so why would this be faster on a car? what would it improve, from the little i know it seems like throttle response would be down, but ive been wrong before
Old 06-14-2004, 12:13 AM
Re: stroker kit
if u are going to be running at the same rpm, then u increases compression (more hp) and displacement (more torque). IT all depends on the specifics of how much u are going to be stroking, what the engine can handle, etc (which i don't know), but if u stroke a lot and u can't rev as high, there would be a trade off of hp for torque (and shitty gas mileage).
Clear Corners
Iridium Spark Plugs
Old 06-14-2004, 08:05 AM
Re: stroker kit
thanks...
Old 07-25-2004, 05:35 AM
95RSV's Avatar
95RSV 95RSV is offline
Re: stroker kit
a stroker kit consists of pistons,rings,rods and crankshaft.
Old 07-25-2004, 06:02 AM
engineer's Avatar
engineer engineer is offline
Banned
Send a message via Yahoo to engineer
Re: stroker kit
in the same way destroking an engine will lift the rev ceiling, just look at the crazy turbo 4wd dahlback racing golf
